SV: [mapserver-users] to large files? or
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jun 17 09:00:06 EDT 2008
I would follow the instructions that I provided in the previous post
to make sure it is not a problem with your .map file. Once you have
ruled that out, then you know it must be a problem with your Chameleon
settings. (if that is the case, then you should use the Chameleon
mailing list for this question) You might also want to try your
Chameleon application with another mapfile.
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
On 16-Jun-08, at 6:52 PM, Henric Ernstson wrote:
> Hi list and Jeff I have looked at my app and my map-file
> eny one out there knowing any thing about chameleon line 215
> say
> $this->oMap = ms_newMapObj($szMapFile, $szMapFilePath);
> and that give me problem using large datasets.
> -----Ursprungligt meddelande-----
> Fran: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org]For Jeff McKenna
> Skickat: den 16 juni 2008 00:29
> Till: Mapserver-users
> Amne: Re: [mapserver-users] to large files? or
> MapServer (through the GDAL library) handles raster files of that size
> very well. To test your mapfile I would:
> 1) open a command prompt and execute c:\ms4w\setenv.bat)
> 2) cd into your map folder
> 3) test the mapfile with a shp2img command:
> shp2img -m base3_b.map -o test.png -map_debug 3
> A png should be produced of your map, or an error message should be
> displayed with a line number.
> If shp2img gives no error and produces a valid map image, then it is a
> problem on the application side.
> Jeff McKenna
> On 15-Jun-08, at 2:46 PM, Henric Ernstson wrote:
>> I have a functional chameleon app. I use many raster-data set and
>> shp-files.
>> No I get problem with some new rasterdata that I use. I get the
>> following
>> error. .. ..
>> Yes I have added some wery large dataset (>290 Meg per rasterfile)...
>> Warning: [MapServer Error]: getString(): Parsing error near (8):
>> (line 126)
>> in C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php on
>> line 215
>> Warning: Failed to open map file
>> C:\ms4w\apps\chameleon\samples\htdocs\/../map/base3_b.map in
>> C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php on line
>> 215
>> Fatal error: Call to a member function set() on a non-object in
>> C:\ms4w\apps\chameleon\htdocs\widgets\KeyMap\KeyMap.widget.php on
>> line 197
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
