[MAPSERVER-USERS] MapServer 5.2 Beta 1 Available
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Jun 17 11:45:15 EDT 2008
I doubt it though I guess it would really help us get things tested
given the popularity of
the Windows distribution. There's another beta due out shortly so
perhaps for that one.
As a reminder, we are interested in ANY feedback if you've tried the
beta. A thumbs up
helps us too!
Steve
>>> On 6/16/2008 at 1:47 AM, in message
<17858782.post at talk.nabble.com>, Pål
Kristensen <pal.kristensen at statkart.no> wrote:
> Hi!
> Will there be a MS4W release with containing MapServer 5.2 Beta 1?
> Regards,
> Pål Kristensen
> Steve Lime wrote:
>> Hi folks: MapServer 5.2 Beta 1 has just been released. The source
package
>> is available for download at:
>> http://mapserver.gis.umn.edu/download/beta
>> The list of changes/fixes since 5.0 can be found at the end this
message.
>> This is a significant release so
>> we need your help in testing. 5.2 should compatible with any 5.0
>> applications/mapfiles so it should be
>> relatively easy for folks to test. Please let us know how it goes!
>> The plan is to have 2 beta releases, two release candidates with a
final
>> release the first week in July.
>> More details can be found in the 5.2 release plan at:
http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_2/release_
> plan/
>> Steve
>> Version 5.2.0-beta1 (2008-06-11):
>> - WMS/WFS layers can now specify a proxy servert (#571)
>> - mapwmslayer.c: set QUERY_LAYERS correctly (#2001)
>> - mapwcs.c: handle PARAMETER values correctly (#2509)
>> - SOS: fix various memory leaks (#2412)
>> - mapwcs.c: advertise temporal support in GetCapabilities (#2487)
>> - Fixed flaw in findTag() in maptemplate.c that prevented multiple
tags
>> on the same line being processed under certain conditions.
(#2633)
>> - Return results even when extents are missing (#2420)
>> - Avoid displaying OGR connection strings in error messages (#2629)
>> - WCS: respect wcs_name metadata for GetCoverage and
DescribeCoverage
>> requests (#2036)
>> - CGI: added -nh option to allow for the suppression of content
headers
>> from
>> the command line (#2594)
>> - PostGIS: fix postgis idle-in-transaction problem (#2626)
>> - AGG: enable ellipse symbol rotation for POINT/ANNOTATION layers
(#2617)
>> - RFC36: add more extensions to support templates (#2576)
>> - AGG: allow dashed hatch symbols (#2614)
>> - AGG: enable offset lines of type x -99 (#2588)
>> - AGG: use an agg specific label size calculation function where
>> possible (#2357)
>> - mapogcsld.c: fetch TextSymbolizer/Label/ogc:PropertyName
correctly
>> (#2611)
>> - Don't ignore .qix file when DATA reference includes .shp
extension
>> (#590)
>> - CGI able to alter layers with space and underscores (#2516)
>> - WFS Multipoint query with PostGIS bug fixed (#2443)
>> - Tiling API (RFC 43) mode=tile, tilemode=spheremerc, tile=x y zoom
>> (#2581)
>> - Remove C++-style comments and most other warnings thrown by
-pedantic
>> (#2598)
>> - Fix PostGIS transaction behavior in fcgi situations (#2497,
#2613)
>> - Improve performance for large shape files (#2282)
>> - encode WMS parameters correctly (#1296)
>> - Added alignment option within a scalebar (#2468)
>> - RFC-42 HTTP Cookie Forwarding (#2566)
>> - Fixed handling of encrypted connection strings in postgis driver
(#2563)
>> - mapagg.cpp: AGG: add opacity at the style level (#1155)
>> - mapwms.c: add Cache-Control max-age HTTP header support (#2551)
>> - mapogcsos.c: support URI encoded procedures correctly (#2547)
>> - Added support for EMPTY template with WMS GetFeatureInfo (#546)
>> - Throw an exception if the WCS request does not overlap layer
(#2503)
>> - Acquire TLOCK_PROJ for pj_transform() calls (#2533).
>> - Fixed problem with large imagemaps generating no output (#2526)
>> - mapwms.c: make version optional for GetCapabilities again (#2528)
>> - support URN scheme for components of observed property elements
(#2522)
>> - Fixed gdImagePtr gdPImg memory leak in msSaveImageBufferGD()
(#2525)
>> - mapogcsos.c: handle invalid POST requests (#2521)
>> - mapogcsos.c: handle ACCEPTVERSIONS parameter (#2515)
>> - mapwcs.c/mapwcs11.c: s/neighbour/neighbor/g (#2518)
>> - mapwms.c: relax FORMAT parameter restrictions for GetFeatureInfo
(#2517)
>> - mapwcs.c: support COVERAGE lists for DescribeCoverage (#2508)
>> - mapwcs.c: fix lonLatEnvelope/@srsName (#2507)
>> - mapwcs.c: omit VendorSpecificCapabilities (#2506)
>> - mapwcs.c: test for either resx/resy OR width/height (#2505)
>> - mapwcs.c: make GetCoverage demand one of TIME or BBOX (#2504)
>> - mapwms.c: make GetLegendGraphic listen to TRANSPARENT in
OUTPUTFORMAT
>> (#2494)
>> - OWS: support updatesequence (#2384)
>> - mapwms.c: test VERSION after service=WMS (#2475)
>> - OWS: output Capabilities XML updateSequence if set (#2384)
>> - mapwcs.c: better handling of REQUEST parameter (#2490)
>> - mapwcs.c: point to correct exception schema (#2481)
>> - mapows.c: add version negotiation (#996)
>> - mapwfs.c: return default GML2 when invalid OUTPUTFORMAT passed
(#2479)
>> - mapowscommon.c: add OWS Common style version negotiation (#996)
>> - mapwcs.c: better section parameter handling for CITE (#2485)
>> - mapwfs.c: point to the correct schema for exceptions (#2480)
>> - shp2img.c/shp2pdf.c: clean up usage text, check for invalid
layers
>> (#2066)
>> - completed implementation of RFC24 (#2442, #2032)
>> - mapwcs.c: require VERSION parameter for DescribeCoverage and
>> GetCoverage (#2473)
>> - mapwcs.c: change error token to MS_WCSERR instead of MS_WMSERR
(#2474)
>> - mapwcs.c: set exception MIME type to application/vnd.ogc.se_xml
>> for 1.0.0 (#2470)
>> - mapwcs.c: Generate a decently formatted exception if an WCS XML
POST
>> request
>> is received (#2476).
>> - mapowscommon.c: support OWS Common 1.1.0 as well (#2071)
>> - mapogcsos.c: support SOS 1.0.0 (#2246)
>> - Implement mapObj.setCenter, mapObj.offsetExtent,
mapObj.scaleExtent,
>> rectObj.getCenter at the SWIG API (#2346)
>> - mapogcfilter.c: use USE_LIBXML2 in ifdefs (#2416)
>> - clean up naming conventions of Shapefile API (#599)
>> - use msComputeBounds() instead, since it's already in the codebase
>> (#2087)
>> - set shapeObj bounds from WKT (#2087)
>> - fixed issue where path following labels sometimes used the
supplied
>> setting for position. In all cases with ANGLE FOLLOW we want to
force
>> position MS_CC regardless of what is set in the mapfile.
>> - enforce (-99 -99) to be the penup value for vector symbols
(#1036)
>> - Support for labeling features (polygon & line) prior to clipping.
This
>> results in stable label positions regardless of map extent. (#2447)
>> - Support for quantization and forced palette png output with RGBA
images
>> (#2436)
>> - SLD using a single BBOX filter should generate an SQL ststement
for
>> oracle/postgis/ogr (#2450)
>> - Accurate Calculation of legend size for WMS LegendURL (#2435)
>> - Converted mapogr.cpp to use OGR C API instead of C++ classes to
allow
>> GDAL/OGR updates without having to recompile MapServer (#545,
#697)
>> - add missing space on dashed polygon outlines with svg (#2429)
>> - Restored behavior of MS 4.10 and made WMS STYLES parameter
optional
>> again in GetMap and GetFeatureInfo requests (#2427)
>> - Speed up forced palette rendering (#2422)
>> - WMS GetFeatureInfo: honour FEATURE_COUNT for any INFO_FORMAT and
>> apply the FEATURE_COUNT per layer instead of globally (#2423,
#1686)
>> - enable soft outlines on truetype labels. This is triggered with a
new
>> keyword OUTLINEWIDTH for the LABEL block (#2417)
>> - fix clipping rectangle to take width as well as size into account
>> (#2411)
>> - AGG: added and use a line and polygon adaptor to avoid copying
shapeObj
>> points to an agg path_storage. avoids a few mallocs and a few
copies.
>> - fixed symbolsetObj not to set the SWIG immutable flag permanently
>> don't expose refcount and the symbol attributes (Ticket #2407)
>> - fix for support of entity encoded text in angle follow text
(#2403)
>> - AGG: initial support for native computation of label sizes
(#2357)
>> - AGG: support text symbols specified by their character number
(#2398)
>> - AGG: fix angle orientation for various symbols
>> - allow scientific notation for attributes binded to an int (#2394)
>> - merge GD and AGG label cache drawing functions (#2390)
>> - Enable AGG rendering of bitmap font labels instead of falling back
to
>> GD (#2387)
>> - clean up treatment of encoding and wrap caracter
>> - Fix legend label placement for multiline labels (#2382)
>> - enforce WRAP parameter in legend label (#2382)
>> - AGG: pixel level simplification for line and polygon shapes
(#2381)
>> - fixed blue/green color swapping for space delimited strings bound
to an
>> attribute. (bug 2378)
>> - don't remove points that are checked as being colinear (#2366)
>> - mapowscommon.c: fix namespace leak issues (#2375)
>> - mapogcsos.c: add SWE DataBlock support (#2248)
>> - mapogcsos.c: fix build warnings, namespace and schema pointers
(#2248)
>> - mappdf.c: support output in fastcgi case via msIO_fwrite()
(#2406)
>> - mapogcsos.c: Initial support for POST requests (#2379) and
updated
>> msSOSDispatch() handling
>> - mapogr.cpp: Use pooling api to ensure per-thread sharing of
connections
>> only (#2408)
>> - mapogcsos.c: change substituted variable from sensorid to
procedure
>> (#2409)
>> - maplibxml2.c: Initial implementation of libxml2 convenience
functions
>> - configure: Modified so libxml2 support is requested for WCS and
SOS,
>> and is indicated by USE_LIBXML2 definition. Use @ALL_ENABLED@ in
>> DEFINEs and mapscriptvars generation.
>> - mapresample.c: Fixed support for multi-band data in RAW mode for
>> bilinear
>> and nearest neighbour resamplers (#2364).
>> - mapdraw.c: Improve error reporting if a raster layer requested in
>> a query map (#1842).
>> - mapfile.c: add simple urn:ogc:def:crs:OGC::CRS84 support.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.nabble.com/MapServer-5.2-Beta-1-Available-tp17788950p17858782.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
