[MAPSERVER-USERS] MapServer 5.2 Beta 1 Available
Monier Clement
clement.monier at v-trafic.com
Tue Jun 17 12:30:44 EDT 2008
That would be great because this MS5.2 release seems to give real great
improvements !
As a windows user, I'm going to try to compile the source's release in order
to run some tests and give you some feedback.
I'm still looking forward to downloading the next beta ms4w release.
Thanks for this great job !
Regards,
Clem
-----Message d'origine-----
De : mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] De la part de Pål
Kristensen
Envoyé : lundi 16 juin 2008 08:47
À : mapserver-users at lists.osgeo.org
Objet : Re: [MAPSERVER-USERS] MapServer 5.2 Beta 1 Available
Hi!
Will there be a MS4W release with containing MapServer 5.2 Beta 1?
Regards,
Pål Kristensen
Steve Lime wrote:
> Hi folks: MapServer 5.2 Beta 1 has just been released. The source
> package is available for download at:
> http://mapserver.gis.umn.edu/download/beta
> The list of changes/fixes since 5.0 can be found at the end this message.
> This is a significant release so
> we need your help in testing. 5.2 should compatible with any 5.0
> applications/mapfiles so it should be relatively easy for folks to
> test. Please let us know how it goes!
> The plan is to have 2 beta releases, two release candidates with a
> final release the first week in July.
> More details can be found in the 5.2 release plan at:
> http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_2/r
> elease_plan/
> Steve
> Version 5.2.0-beta1 (2008-06-11):
> - WMS/WFS layers can now specify a proxy servert (#571)
> - mapwmslayer.c: set QUERY_LAYERS correctly (#2001)
> - mapwcs.c: handle PARAMETER values correctly (#2509)
> - SOS: fix various memory leaks (#2412)
> - mapwcs.c: advertise temporal support in GetCapabilities (#2487)
> - Fixed flaw in findTag() in maptemplate.c that prevented multiple tags
> on the same line being processed under certain conditions. (#2633)
> - Return results even when extents are missing (#2420)
> - Avoid displaying OGR connection strings in error messages (#2629)
> - WCS: respect wcs_name metadata for GetCoverage and DescribeCoverage
> requests (#2036)
> - CGI: added -nh option to allow for the suppression of content
> headers from
> the command line (#2594)
> - PostGIS: fix postgis idle-in-transaction problem (#2626)
> - AGG: enable ellipse symbol rotation for POINT/ANNOTATION layers
> (#2617)
> - RFC36: add more extensions to support templates (#2576)
> - AGG: allow dashed hatch symbols (#2614)
> - AGG: enable offset lines of type x -99 (#2588)
> - AGG: use an agg specific label size calculation function where
> possible (#2357)
> - mapogcsld.c: fetch TextSymbolizer/Label/ogc:PropertyName correctly
> (#2611)
> - Don't ignore .qix file when DATA reference includes .shp extension
> (#590)
> - CGI able to alter layers with space and underscores (#2516)
> - WFS Multipoint query with PostGIS bug fixed (#2443)
> - Tiling API (RFC 43) mode=tile, tilemode=spheremerc, tile=x y zoom
> (#2581)
> - Remove C++-style comments and most other warnings thrown by
> -pedantic
> (#2598)
> - Fix PostGIS transaction behavior in fcgi situations (#2497, #2613)
> - Improve performance for large shape files (#2282)
> - encode WMS parameters correctly (#1296)
> - Added alignment option within a scalebar (#2468)
> - RFC-42 HTTP Cookie Forwarding (#2566)
> - Fixed handling of encrypted connection strings in postgis driver
> (#2563)
> - mapagg.cpp: AGG: add opacity at the style level (#1155)
> - mapwms.c: add Cache-Control max-age HTTP header support (#2551)
> - mapogcsos.c: support URI encoded procedures correctly (#2547)
> - Added support for EMPTY template with WMS GetFeatureInfo (#546)
> - Throw an exception if the WCS request does not overlap layer (#2503)
> - Acquire TLOCK_PROJ for pj_transform() calls (#2533).
> - Fixed problem with large imagemaps generating no output (#2526)
> - mapwms.c: make version optional for GetCapabilities again (#2528)
> - support URN scheme for components of observed property elements
> (#2522)
> - Fixed gdImagePtr gdPImg memory leak in msSaveImageBufferGD() (#2525)
> - mapogcsos.c: handle invalid POST requests (#2521)
> - mapogcsos.c: handle ACCEPTVERSIONS parameter (#2515)
> - mapwcs.c/mapwcs11.c: s/neighbour/neighbor/g (#2518)
> - mapwms.c: relax FORMAT parameter restrictions for GetFeatureInfo
> (#2517)
> - mapwcs.c: support COVERAGE lists for DescribeCoverage (#2508)
> - mapwcs.c: fix lonLatEnvelope/@srsName (#2507)
> - mapwcs.c: omit VendorSpecificCapabilities (#2506)
> - mapwcs.c: test for either resx/resy OR width/height (#2505)
> - mapwcs.c: make GetCoverage demand one of TIME or BBOX (#2504)
> - mapwms.c: make GetLegendGraphic listen to TRANSPARENT in
> OUTPUTFORMAT
> (#2494)
> - OWS: support updatesequence (#2384)
> - mapwms.c: test VERSION after service=WMS (#2475)
> - OWS: output Capabilities XML updateSequence if set (#2384)
> - mapwcs.c: better handling of REQUEST parameter (#2490)
> - mapwcs.c: point to correct exception schema (#2481)
> - mapows.c: add version negotiation (#996)
> - mapwfs.c: return default GML2 when invalid OUTPUTFORMAT passed
> (#2479)
> - mapowscommon.c: add OWS Common style version negotiation (#996)
> - mapwcs.c: better section parameter handling for CITE (#2485)
> - mapwfs.c: point to the correct schema for exceptions (#2480)
> - shp2img.c/shp2pdf.c: clean up usage text, check for invalid layers
> (#2066)
> - completed implementation of RFC24 (#2442, #2032)
> - mapwcs.c: require VERSION parameter for DescribeCoverage and
> GetCoverage (#2473)
> - mapwcs.c: change error token to MS_WCSERR instead of MS_WMSERR
> (#2474)
> - mapwcs.c: set exception MIME type to application/vnd.ogc.se_xml
> for 1.0.0 (#2470)
> - mapwcs.c: Generate a decently formatted exception if an WCS XML POST
> request
> is received (#2476).
> - mapowscommon.c: support OWS Common 1.1.0 as well (#2071)
> - mapogcsos.c: support SOS 1.0.0 (#2246)
> - Implement mapObj.setCenter, mapObj.offsetExtent, mapObj.scaleExtent,
> rectObj.getCenter at the SWIG API (#2346)
> - mapogcfilter.c: use USE_LIBXML2 in ifdefs (#2416)
> - clean up naming conventions of Shapefile API (#599)
> - use msComputeBounds() instead, since it's already in the codebase
> (#2087)
> - set shapeObj bounds from WKT (#2087)
> - fixed issue where path following labels sometimes used the supplied
> setting for position. In all cases with ANGLE FOLLOW we want to force
> position MS_CC regardless of what is set in the mapfile.
> - enforce (-99 -99) to be the penup value for vector symbols (#1036)
> - Support for labeling features (polygon & line) prior to clipping.
> This results in stable label positions regardless of map extent.
> (#2447)
> - Support for quantization and forced palette png output with RGBA images
> (#2436)
> - SLD using a single BBOX filter should generate an SQL ststement for
> oracle/postgis/ogr (#2450)
> - Accurate Calculation of legend size for WMS LegendURL (#2435)
> - Converted mapogr.cpp to use OGR C API instead of C++ classes to allow
> GDAL/OGR updates without having to recompile MapServer (#545, #697)
> - add missing space on dashed polygon outlines with svg (#2429)
> - Restored behavior of MS 4.10 and made WMS STYLES parameter optional
> again in GetMap and GetFeatureInfo requests (#2427)
> - Speed up forced palette rendering (#2422)
> - WMS GetFeatureInfo: honour FEATURE_COUNT for any INFO_FORMAT and
> apply the FEATURE_COUNT per layer instead of globally (#2423, #1686)
> - enable soft outlines on truetype labels. This is triggered with a new
> keyword OUTLINEWIDTH for the LABEL block (#2417)
> - fix clipping rectangle to take width as well as size into account
> (#2411)
> - AGG: added and use a line and polygon adaptor to avoid copying shapeObj
> points to an agg path_storage. avoids a few mallocs and a few copies.
> - fixed symbolsetObj not to set the SWIG immutable flag permanently
> don't expose refcount and the symbol attributes (Ticket #2407)
> - fix for support of entity encoded text in angle follow text (#2403)
> - AGG: initial support for native computation of label sizes (#2357)
> - AGG: support text symbols specified by their character number
> (#2398)
> - AGG: fix angle orientation for various symbols
> - allow scientific notation for attributes binded to an int (#2394)
> - merge GD and AGG label cache drawing functions (#2390)
> - Enable AGG rendering of bitmap font labels instead of falling back to
> GD (#2387)
> - clean up treatment of encoding and wrap caracter
> - Fix legend label placement for multiline labels (#2382)
> - enforce WRAP parameter in legend label (#2382)
> - AGG: pixel level simplification for line and polygon shapes (#2381)
> - fixed blue/green color swapping for space delimited strings bound to an
> attribute. (bug 2378)
> - don't remove points that are checked as being colinear (#2366)
> - mapowscommon.c: fix namespace leak issues (#2375)
> - mapogcsos.c: add SWE DataBlock support (#2248)
> - mapogcsos.c: fix build warnings, namespace and schema pointers
> (#2248)
> - mappdf.c: support output in fastcgi case via msIO_fwrite() (#2406)
> - mapogcsos.c: Initial support for POST requests (#2379) and updated
> msSOSDispatch() handling
> - mapogr.cpp: Use pooling api to ensure per-thread sharing of connections
> only (#2408)
> - mapogcsos.c: change substituted variable from sensorid to procedure
> (#2409)
> - maplibxml2.c: Initial implementation of libxml2 convenience
> functions
> - configure: Modified so libxml2 support is requested for WCS and SOS,
> and is indicated by USE_LIBXML2 definition. Use @ALL_ENABLED@ in
> DEFINEs and mapscriptvars generation.
> - mapresample.c: Fixed support for multi-band data in RAW mode for
> bilinear
> and nearest neighbour resamplers (#2364).
> - mapdraw.c: Improve error reporting if a raster layer requested in
> a query map (#1842).
> - mapfile.c: add simple urn:ogc:def:crs:OGC::CRS84 support.
View this message in context:
http://www.nabble.com/MapServer-5.2-Beta-1-Available-tp17788950p17858782.htm
l
Sent from the Mapserver - User mailing list archive at Nabble.com.
