VS: [mapserver-users] using vector data format
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jun 18 09:01:45 EDT 2008
Your problem is that Mapserver does not support AutoCAD dwg file format. You need to convert it first to some supported format, which are listed at
http://gdal.org/ogr/ogr_formats.html
-Jukka Rahkonen.
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: valerio vianello
Lähetetty: ke 18.6.2008 12:24
Vastaanottaja: mapserver
Aihe: [mapserver-users] using vector data format
Dear all,
I tried without success to use a dwg file as data input for a layer into the mapfile.
My goal is to use a vector data to build the main layer of the map so that when the map is "resize" the image quality will be good at every size.
Mapserver give me this error "File not found or unsupported format."
and my test map file is this:
MAP
IMAGETYPE PNG
EXTENT 24.914925 60.162912 24.917090 60.164152
SIZE 300 200
SHAPEPATH "/var/www/"
IMAGECOLOR 255 255 255
WEB
TEMPLATE 'test.html'
IMAGEPATH '/var/www/tmp/data_tmp/'
IMAGEURL '/tmp/data_tmp/'
END
# Start of LAYER DEFINITIONS -----------------------------------------------------------
LAYER
NAME "test"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "/var/www/demo1/images/b1_f2.dwg"
STATUS DEFAULT
CLASS
END
END
END
any suggetsion ?
Thanks
Valerio
___________________________________
Scopri il Blog di Yahoo! Mail: trucchi, novità, consigli... e la tua opinione!
http://www.ymailblogit.com/blog/
