R: VS: [mapserver-users] using vector data format
valerio vianello valerio.vianello at yahoo.it
Wed Jun 18 09:32:35 EDT 2008
Hi Jukka,
I took the list from http://mapserver.gis.umn.edu/docs/howto/ogr_howto and there
autocad format is present among supported vector format. maybe that list isn't updated :S.
Anyhow my problem is that my start image is a svg file and I used a software to convert it in autocad format.
Do you know a software to convert svg file in another vector format supported by mapserver ?
thanks
Valerio
--- Mer 18/6/08, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> ha scritto:
Da: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
Oggetto: VS: [mapserver-users] using vector data format
A: valerio.vianello at yahoo.it, "mapserver" <mapserver-users at lists.osgeo.org>
Data: Mercoledì 18 giugno 2008, 15:01
Your problem is that Mapserver does not support AutoCAD dwg file format.  You
need to convert it first to some supported format, which are listed at
http://gdal.org/ogr/ogr_formats.html
-Jukka Rahkonen.
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: valerio
vianello
Lähetetty: ke 18.6.2008 12:24
Vastaanottaja: mapserver
Aihe: [mapserver-users] using vector data format
Dear all,
I tried without success to use a dwg file as data input for a layer into the
mapfile.
My goal is to use a vector data to build the main layer of the map so that when
the map is "resize" the image quality will be good at every size.
Mapserver give me this error   "File not found or unsupported
format."
and my test map file is this:
MAP
  IMAGETYPE      PNG
  EXTENT         24.914925 60.162912 24.917090 60.164152
  SIZE           300 200
  SHAPEPATH      "/var/www/"
  IMAGECOLOR     255 255 255
  WEB
    TEMPLATE  'test.html'
    IMAGEPATH '/var/www/tmp/data_tmp/'
    IMAGEURL  '/tmp/data_tmp/'
  END
 # Start of LAYER DEFINITIONS
LAYER
   NAME "test"
   TYPE POLYGON
   CONNECTIONTYPE OGR
   CONNECTION "/var/www/demo1/images/b1_f2.dwg"
   STATUS DEFAULT
   CLASS
   END
END
END
any suggetsion ?
Thanks
Valerio
      ___________________________________
Scopri il Blog di Yahoo! Mail: trucchi, novità, consigli... e la tua opinione!
http://www.ymailblogit.com/blog/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080618/3119ec6d/attachment.html
