[mapserver-users] LABELANGLEITEM in MS 5.0 using OGR:LabelAngle for annotation layer
Tamas Szekeres szekerest at gmail.com
Wed Jun 18 10:02:08 EDT 2008
According to
http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/mapserver/MIGRATION_GUIDE.TXT
You have to use in your mapfile something like:
LABEL
  ANGLE [OGR:LabelAngle]
END
Best regards,
Tamas
2008/6/18 Mike Saunt <mikesaunt at gmail.com>:
> Hi All
> We're trying to get an annotation layer from MapInfo format (text only now
> lines, points etc to follow) to render but to use the angle stored in the
> MapInfo feature (not from an attribute column) - we used to be able to use
> LABELANGLEITEM "OGR:LabelAngle" in v4 but v5 seems to have us stumped as the
> bindings seem to only work against fields names
> We also found the below in the OGR help but I can't seem to find the correct
> syntax
> Special OGR:Label* attributes
> Posted by Daniel Morissette at 2007-09-13 07:40
> This should probably be added to the docs:
> When using CONNECTIONTYPE OGR, there are special attributes called
> OGR:LabelText, OGR:LabelAngle and OGR:LabelSize that can be used as
> LABELITEM, ANGLE and SIZE in the label definition for your annotation layer.
> You can use that as an alternative to using STYLEITEM AUTO.H
> Anyone able to help us?
> Cheers
> Mike
> mapserver-users at lists.osgeo.org
