[mapserver-users] WMS for Google Earth
Tony Frame
jaframe at net-yan.com
Thu Jun 19 12:47:30 EDT 2008
----- Original Message -----
To: mapserver-users at lists.osgeo.org
Sent: Tuesday, 17 June, 2008 5:04 AM
Subject: [mapserver-users] WMS for Google Earth
Hello, I am trying to develop WMS to be compatible with Google Earth. My map
file seems to return a healthy XML file (no errors, and works in Cartoweb),
but it will not project (at all) in Google Earth?
Can someone direct me toward a solution or documentation on this subject?
My XML file looks like this:
Thanks, Ben
Ben,
If you try to access your xlink:href :
http://quakeloss.ethz.ch/cgi-bin/mapserv?map=QL2WMS_22.map&
you'll see the message :
msLoadMap(): Unable to access file. (QL2WMS_22.map)
Full path to your map file needs to be specified eg on a Fedora / RH system
you'd need something like
http://quakeloss.ethz.ch/cgi-bin/mapserv?map=%2Fvar%2Fwww%2Fhtml%2FMyApplicationMapfileDirectory%2FQL2WMS_22.map&
This is probably set in WEB METADATA section of your map file as
"wms_onlineresource".
I've got something like this to work in Google Earth by adding an "Image
Overlay" and setting "WMS Parameters" under the Refresh tab. Add the
xlink:href above (with the correct map file path) to the WMS Server box - if
all is correct you should get a list of layers you can add, if not you'll
get an error message something like "Get capabilities failed".
Google Earth seems to always set a default image WIDTH and HEIGHT to 500 x
500 which may not be appropriate if the map window is not square - once
you've setup the WMS server succesfully you can change these in the link box
under "Properties" of the overlay. Or save to a *.kml file and edit the
parameters in the file and reload in Google Earth.
The auto refresh in Google Earth seems a bit flaky ... sometimes needs a
manual "kick" to get it going the first time and theen seems ok thereafter.
Other problem I've had is that on Linux GE doesn't seem to be able to access
mapserver using https. GE from windows pops up an authentication /
certificate warning box and then connects to the same https server without
any problems.
Hope this helps
Regards
Tony
