[MAPSERVER-USERS] Mapserver does partial search of dbf file
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jun 23 17:19:13 EDT 2008
I would also try ogrinfo to see how GDAL reads your shapefile:
ogrinfo buildings.shp buildings -summary
- use that to see if the feature count is correct
- use that to see the individual records
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
On 23-Jun-08, at 4:30 PM, JayDub wrote:
> Hi all, I'm having a severe problem with MapServer. It seems to only
> be
> searching PARTS of a dbf file. Have a look at my layer.
> LAYER
> NAME "AllFaculties"
> DATA '/home/jolly/web/shps/campus/mit/buildings.shp'
> TRANSFORM true
> CLASSITEM 'Name'
> TYPE polygon
> GROUP "AllFaculties"
> METADATA
> "queryable" "true"
> "searchfield" "Name"
> "fields" "Name:name,Category:cat"
> END # METADATA
> CLASS
> TEMPLATE "template.html"
> END # CLASS
> END # LAYER
> Simple and to the point... some how there are records in the dbf
> file that I
> can't reach via search. I'm using kamap's search script that
> basically uses
> mapscript's queryByAttributes(.....) to get results.
> Id Category Name
> 0 Residence/Hall Karma Hall
> 0 Residence/Hall Terry Hall
> Above is an extract of my dbf file... Mapserver finds the first
> record but
> does not find the 2nd record. And that's generally how it is with my
> dbf
> file. It'll find a record here and then not find a couple that
> follow after,
> then it's able to find records that follow after.
> Hope some one can help... coz this project was due 3 fridays ago and
> my boss
> is a lil... perturbed (to be MOST diplomatic, and naive)
> View this message in context: http://www.nabble.com/Mapserver-does-partial-search-of-dbf-file-tp18077780p18077780.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
