[MAPSERVER-USERS] No Labels on PostGIS Layer
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jun 23 17:27:52 EDT 2008
You're restricting your result to field_in of 50204. Does that record
have values for the field_name?
On Jun 23, 2008, at 2:07 PM, osprey44 wrote:
> I have a particular layer in which I cannot seem to display the
> labels. The
> shape displays correctly. I have tried multiple columns to use as the
> label, but all do not show. Below is the specific chunk of the map
> file:
> LAYER
> NAME "field"
> TYPE POLYGON
> STATUS ON
> CONNECTION "user=web password=apacheweb08 dbname=base_dev
> host=localhost
> port=5432"
> CONNECTIONTYPE postgis
> DATA "field_boundary from (select fb.field_id as field_id,
> fb.field_id as
> OID, fb.field_boundary as field_boundary, fb.acres as acres,
> f.field_name as
> field_name from field_boundary fb, fields f where
> fb.field_id=f.field_id) as
> field_boundary"
> FILTER "field_id in ('50204')"
> LABELITEM "field_name"
> CLASS
> STYLE
> OUTLINECOLOR 255 0 0
> COLOR -1 -1 -1
> WIDTH 3
> END
> LABEL
> TYPE TRUETYPE
> FONT arial
> SIZE 10
> ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> POSITION AUTO
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> DEBUG ON
> END
> http://www.nabble.com/file/p18078514/fieldMap.jpg
> View this message in context: http://www.nabble.com/No-Labels-on-PostGIS-Layer-tp18078514p18078514.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Paul Ramsey
+1 250 885 0632
