[MAPSERVER-USERS] Mapserver does partial search of dbf file
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Jun 23 18:49:56 EDT 2008
Next:
- use shp2img to produce a map image of the full extents of the map
	shp2img -m your.map -o test.png -map_debug 3
- if the missing records in your search are displayed on that map
image, then you know it is a problem with your application...which in
your case is a ka-map search script, and you would then take this
problem to the ka-map mailing list
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
On 23-Jun-08, at 6:36 PM, JayDub wrote:
> Thanks for that... Hmmm... ALL the records are shown using ogrinfo.
> I used
> the "ogrinfo buildings.shp buildings" command along with grep and
> was able
> to find all the records I could not find using the queryByAttributes
> method.
> What next then? :-(
> Any other suggestions on why queryByAttributes could be not returning
> partial results for such a simple layer?
> Jeff McKenna-3 wrote:
>> I would also try ogrinfo to see how GDAL reads your shapefile:
>> ogrinfo buildings.shp buildings -summary
>> 	- use that to see if the feature count is correct
>> 	- use that to see the individual records
