[MAPSERVER-USERS] 5.2 b2 - WMS GetMap bug
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Tue Jun 24 08:47:10 EDT 2008
FYI there is an open ticket against this http://trac.osgeo.org/mapserver/ticket/2569
..Tom
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org on behalf of Pål Kristensen
Sent: Tue 24-Jun-08 08:45
To: mapserver-users at lists.osgeo.org
Subject: [MAPSERVER-USERS] 5.2 b2 - WMS GetMap bug
Hi!
I have done some testing on the WMS server support, and there is a bug
regarding GetMap requests. MapServer throes a error message if the request
lacks the service=wms parameter. This is not right because regarding to the
WMS specification, service isn't a mandatory parameter to the GetMap
request. I know that this issue has been discussed before, and I thought the
bug was fixed a while ago.
Regards,
Pål kristensen
Steve Lime wrote:
> Hi folks: MapServer 5.2 Beta 2 has just been released. The source package
> is available for download at:
> http://mapserver.gis.umn.edu/download/beta
> The list of changes/fixes since 5.2-beta1 can be found at the end this
> message. This is a significant release so
> we need your help in testing. 5.2 should compatible with any 5.0
> applications/mapfiles so it should be
> relatively easy for folks to test. Please let us know how it goes!
> The plan is now to have 3 beta releases, 1 release candidate with a final
> release the first week in July.
> More details can be found in the 5.2 release plan at:
> http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_2/release_plan/
> Steve
> Version 5.2.0-beta2 (2008-06-18):
> - Fixed possible buffer overrun with Oracle Spatial driver (#2572)
> - mapogcsos.c: support srsName in GetObservation (#2414)
> - Filter Encoding: Modify DWithin definition (#2564)
> - Added webObj legendformat and browseformat mapping in PHP MapScript
> (#2309)
> - Removed static buffer size limit in msIO_*printf() functions (#2214)
> - Fixed libiconv detection in configure for OSX 10.5 64 bit (#2396)
> - mapstring.c: possible buffer overflow in msGetPath (#2649)
> - maputil.c: Correct expression evaluation with text containing
> apostrophes (#2641)
> - mapwfs.c: Possibly generate an error message when applying filter
> encoding (#2444)
> - Added MS_LABEL_BINDING constants for SWIG MapScript (#2643)
> - mapogcsos.c: fix POST support (#2379)
> - maplibxml2.c: helper functions XML POST fix (#2379)
> - mapwfs.c: fix segfault when srsName is not passed on BBOX Filter (#2644)
> - mapwfs.c: do not return error for empty query results (#2444)
> - Remove C++-style comments and most other warnings thrown by -pedantic
> (#2598)
> - mapwfs.c/mapwfs11.c: set GML MIME type correctly
> - mapogcsos.c: advertise supported SRS list via
> MAP.WEB.METADATA.sos_srs (#2414)
> - mapwfs.c: set layer extent to map extent for default
> GetFeature requests with no spatial predicates (#1287)
View this message in context: http://www.nabble.com/MapServer-5.2-Beta-2-Available-tp17996897p18090194.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
