[mapserver-users] Newby Question - hello world
Fawcett, David
David.Fawcett at state.mn.us
Wed Jun 25 15:22:01 EDT 2008
My guess is that you are using MapServer 5.x and the book was written
for < 5.x
If you call your mapfile in mode=map, it will still work, that points to
the html template.
With 5.0, the variable names used for substitution have changed. You
will need to edit the hidden variables in your template.
Take a look at this post for more info.
http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg15557.html
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Katja
Loeffler
Sent: Wednesday, June 25, 2008 1:45 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Newby Question - hello world
Hi there,
in the "Beginning Mapserver" book there is an example which should only
display a box showing "Hello Map"
Well, although I have other examples (not from that book) that do run, I
don't get this one running ... *sigh*
The error I get is
loadWeb(): Unknown identifier. Parsing error near (/var/www/tmp/):(line
1)
I have no clue *awk*.
I googled around but afterwards I still had no clue ...
The mapfile looks like this:
# This is our "Hello World" mapfile
NAME "Hello World"
SIZE 400 300
IMAGECOLOR 249 245 186
IMAGETYPE png
EXTENT -1.0 -1.0 1.0 1.0
WEB
TEMPLATE "/var/www/mapserver/hello/hello.html"
IMAGEPATH "/var/www/tmp/"
IMAGEURL "/tmp/"
END
LAYER
STATUS default
TYPE point
FEATURE
POINTS 0.00 0.00 END
TEXT "Hello World"
END # end feature
CLASS
STYLE
COLOR 255 0 0
END
LABEL
TYPE bitmap
END
END
END
END
The hello.html like this:
<html>
<head> <title>MapServer Hello World</title></head>
<body>
<form method=POST action="/cgi-bin/mapserv">
<input type="submit" value="Click Me">
<input type="hidden" name="map"
value="/home/mapdata/hello.map">
<input type="hidden" name="map_web_imagepath"
value="/var/www/tmp/">
</form>
<IMG SRC="[img]" width=400 height=300 border=0>
</body>
</html>
Thanks in advance!
Katja
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
