[mapserver-users] Basic Projection Help
Matthew Pettis
matthew.pettis at gmail.com
Sat Jun 28 12:05:17 EDT 2008
Thanks to the both of you for your help -- that helps me quite a bit to
understand that how to reproject a srid=-1 on the fly and how i should go
about permanently fixing it in my geometry table.
Take care,
Matt
On Sat, Jun 28, 2008 at 9:35 AM, Paul Spencer <pspencer at dmsolutions.ca>
wrote:
> There is normally a constraint set on postgis tables that specifies the
> SRID, if you want to change the SRID then you need to drop the constraint,
> set the SRID and optionally put back the constraint with the correct SRID.
> I do not believe this is necessary to achieve what you want, though. An
> SRID of -1 tells postgis to return the geometry as is to mapserver.
> Mapserver then doesn't know what the projection of the data is, but that is
> okay because you can provide an PROJECTION object on your layer in
> mapserver. Then mapserver knows what the projection of the data is without
> having to consult postgis and will be able to reproject the data for you.
> So you should be able to leave your data in the database with SRID -1 and
> put
> PROJECTION
> "init=epsg:26915"
> END
> in your layer. Then if you use a different projection at the MAP level,
> mapserver knows that your data is in UTM zone 15 and will reproject it on
> the fly.
> If you are *always* going to reprojecting your data then you should
> actually transform it in the database so that you don't suffer from
> reprojection overhead on every request.
> Cheers
> Paul
> On 28-Jun-08, at 2:12 AM, pcreso at pcreso.com wrote:
> Hi Matthew,
>> If you loaded it from shapefiles using shp2pgsql, then use the -s flag to
>> set the srid to the correct value.
>> If you \d your table, I think you'll find a constraint on it setting the
>> srid, as well as the geometrycolumns entry.
>> The simplest way to get things working with mapserver may well be to leave
>> it as -1 in the database (& geometrycolumns entry) & in your mapserver
>> mapfile data statement, specify the sql returns setsrid(geom,26915) instead
>> of geom, so postgis returns the values with the appropriate SRID set,
>> irrespective of what the database actually stores.
>> That will get things working until you load the data with the correct
>> srid.
>> HTH,
>> Brent Wood
>> --- On Sat, 6/28/08, Matthew Pettis <matthew.pettis at gmail.com> wrote:
>> From: Matthew Pettis <matthew.pettis at gmail.com>
>>> Subject: [mapserver-users] Basic Projection Help
>>> To: "Mapserver-users" <mapserver-users at lists.osgeo.org>
>>> Date: Saturday, June 28, 2008, 5:47 PM
>>> Hello,
>>> I'm trying to get a handle on projections and
>>> reprojections. I have a
>>> dataset in a postgis database table that is in epsg:26915
>>> (it's the state of
>>> MN). I know this from the metadata provided by the
>>> provider (state of
>>> Minnesota itself).
>>> When I loaded it into postgis, the geometry_columns row for
>>> this
>>> table/column combo set srid=-1. As I know that this is in
>>> epsg:26915, I
>>> manually changed the geometry_columns row entry to it (see:
>>> geometry_columns === section).
>>> Problem is, I get an error of using two different
>>> geometries. Anybody have
>>> any idea how i set the srid to the correct value of
>>> epsg:26915? I'd like to
>>> set this correctly so I can reproject it as necessary. The
>>> map will render
>>> with srid=-1, but then I don't think I can reproject
>>> the image correctly,
>>> right?
>>> below are what I think are the important sections to this
>>> problem. Thanks
>>> in advance for your help.
>>> Matt
>>> === url ===
>>> http://localhost/cgi-bin/mapserv.exe?map=C:\ms4w\Apache\htdocs\ol<http://localhost/cgi-bin/mapserv.exe?map=C:%5Cms4w%5CApache%5Chtdocs%5Col>
>>> \mapreproj.map&mode=map
>>> === error message ===
>>> msDrawMap(): Image handling error. Failed to draw layer
>>> named 'state'.
>>> msPOSTGISLayerWhichShapes(): Query error. Error executing
>>> POSTGIS SQL
>>> statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR
>>> FOR SELECT
>>> asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text
>>> from
>>> shp_state WHERE the_geom &&
>>> setSRID('BOX3D(141095.125 4809728.25,810342.625
>>> 5478975.75)'::BOX3D,
>>> find_srid('','shp_state','the_geom')
>>> ) -ERROR:
>>> Operation on two geometries with different SRIDs
>>> === geometry_columns ===
>>> oid;f_table_catalog;f_table_schema;f_table_name;f_geometry_column;coor_dimension;srid;type
>>> 336791;"''";"public";"shp_state";"the_geom";2;26915;"MULTIPOLYGON"
>>> === mapreproj.map ===
>>> MAP
>>> # Map attributes
>>> IMAGETYPE PNG
>>> EXTENT 184056.505 4809728.25 767381.245 5478975.75
>>> SIZE 600 600
>>> IMAGECOLOR 255 255 255
>>> FONTSET
>>> "C:/ms4w/Apache/htdocs/fonts/fonts.list"
>>> # Web settings
>>> WEB
>>> IMAGEPATH "C:/ms4w/Apache/htdocs/tmp/"
>>> IMAGEURL "/tmp/"
>>> END
>>> # State
>>> # Background shows through missing precincts to show
>>> where no votes will
>>> be coming from
>>> LAYER
>>> NAME "state"
>>> CONNECTIONTYPE postgis
>>> CONNECTION "user=postgres dbname=gisvote
>>> password=postgres"
>>> DATA "the_geom from shp_state"
>>> STATUS default
>>> TYPE polygon
>>> CLASS
>>> NAME "state"
>>> COLOR 200 200 200
>>> END
>>> END # Layer state
>>> END
>>> It is from the wellspring of our despair and the places
>>> that we are broken
>>> that we come to repair the world.
>>> -- Murray
>>> Waas_______________________________________________
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
It is from the wellspring of our despair and the places that we are broken
-- Murray Waas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080628/d9ff1c84/attachment.html
