[mapserver-users] Projecting coordinates without drawing maps?
Ray Collett 3dlover at gmail.com
Sun Jun 29 15:12:22 EDT 2008
My script will be run very infrequently (a couple times a day), but within
the script I expect to reproject several thousand points each time.  I
assume the dictionary lookup occurs only when ms_newprojectionobj() is
called and not when $poPoint->project() is called?  As long as that's the
case, then I'm good.
It's nice to get some insight as to how mapserver is working though.
Thanks.
-Ray
On Sat, Jun 28, 2008 at 3:02 PM, Paul Spencer <pspencer at dmsolutions.ca>
wrote:
> Note that the method of using init=<dictionary>:<value> is still
> inefficient for mapserver because proj has to parse the rather large epsg
> file to find the appropriate proj string.  If you are just doing some
> one-off translations then no big deal obviously, but if you are setting up a
> service to reproject or are setting up a map file with projections, then it
> can make quite a big difference.
--==-- Ray Collett --==--
Technical Director; Newlands & Co. Inc.
503.287.8000 x520 3dlover at gmail.com
www.nc3d.com www.norwesters.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080629/582deca2/attachment.html
