[mapserver-users] Projection help: proj command line
Dirk Jesko
ml.dje at geocontent.de
Mon Jun 30 03:05:30 EDT 2008
Hi Matthew,
try cs2cs instead of proj, e.g.
cs2cs +init=epsg:26915 +to +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
+lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs
With proj you have to do the inverse projection from epsg:26915 (your
from projection) to latlon/wgs84 (epsg:4326) first,
proj -I -f "%.8f" +init=epsg:26915
In a second step project the resulting latlon coordinate into your
to-projection:
proj -f "%.4f" +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
Both version should work. Just for comparison, I got the following
result for the first point of your extent:
epsg:26915 : 184056.505, 4809728.25
epsg:4326 : -96.89976708 43.37391004
your to projection: -10786832.7293 5369059.0540
I hope, that this is correct and will help.
Dirk
> Hi,
> This question is tangential to Mapserver, but critical to me
> nonetheless. I'm trying to reproject a shapefile in a mapfile from
> PROJECTION
> "init=epsg:26915"
> END
> to
> PROJECTION
> "+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
> +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"
> END
> my extent in the 'from' projection are:
> EXTENT 184056.505 4809728.25 767381.245 5478975.75
> Can someone help me figure out what my EXTENT should be in my 'to'
> projection? I've tried the following extents derived from the 'proj'
> command line outputs as extents, but was not successful:
> $ proj -I -f "%.4f" +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> +wktext +no_defs
> 1.6534 39.6121
> 6.8935 44.0874
> $ proj -I -f "%.4f" +init=epsg:26915
> -96.8998 43.3739
> -89.3140 49.4047
> Anybody have any ideas what I am doing wrong? Do I somehow have to
> chain projections together to get from my 'from' projection to my 'to'
> projection?
> Thanks,
> Matt
> It is from the wellspring of our despair and the places that we are
> broken that we come to repair the world.
> -- Murray Waas
> mapserver-users at lists.osgeo.org
