[mapserver-users] problem with library
Carlo Pelliconi
c.pelliconi at sis-ter.it
Mon Jun 30 03:23:07 EDT 2008
I use Mapscript on Debian: I had the same "dbase.so" problem.
I've solved downloading php source and building manually the dbase.so
from that source.
Now it works.
Bye, Carlo
Daniel Morissette ha scritto:
> MapServer doesn't have any direct dependency on PHP's dbase module, so
> this is not a MapServer/MapScript problem, you could simply use
> php_mapscript without it. If you need the dbase module to deal with
> .dbf files then this is really a Ubuntu problem (it doesn't provide
> the dbase module) and the following article may help:
> http://boutell.livejournal.com/935243.html
> Daniel
> Guillermo Korell wrote:
>> I have a problem using mapscrip for php5 on Ubuntu 8.04. I've an
>> error when i want to load dynamically a library, in the following line:
>> dl("php_dbase.so");
>> the error is:
>> *Warning*: dl() [function.dl <http://piai04/prueba/function.dl>]:
>> Unable to load dynamic library
>> '/usr/lib/php5/20060613+lfs/php_dbase.so' -
>> /usr/lib/php5/20060613+lfs/php_dbase.so: cannot open shared object
>> file: No such file or directory in */home/gkorell/prueba/index.php*
>> on line *2*
>> I want to install this library for php but I don't found it. What
>> can i do?
>> Thanks
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
ing. Carlo Pelliconi
SIS.TER
www.sis-ter.it
via Mentana, 10
40026 Imola (BO) Italy
tel +39 0542 364034
fax +39 0542 612130
ATTENZIONE!
Questo documento è indirizzato esclusivamente al destinatario. Tutte le
informazioni ivi contenute, compresi eventuali allegati, sono soggette
a riservatezza secondo i termini del D.Lgs. 196/2003 in materia di
"privacy" e ne è proibita l'utilizzazione da parte di altri soggetti. Si ricorda che la diffusione l'utilizzo e/o la conservazione dei dati ricevuti per errore costituisce violazione di carattere penale ai sensi dell'art. 616 Codice penale (Violazione, sottrazione e soppressione di corrispondenza). Se avesse ricevuto per errore questo messaggio, La preghiamo cortesemente di contattare il mittente al più presto e di cancellare il messaggio subito dopo. Grazie.
ATTENTION!
This message is being sent from Sis.Ter S.p.A. and may contain information which is confidential or privileged. If you are not the intended recipient, please advise the sender immediately by reply e-mail and delete this message and any attachments without retaining a copy. Any unauthorized use of the content of this message is a breach of your duty to respect the confidentiality of the correspondence between other persons and can expose the responsible party to civil and/or criminal penalties (D.Lgs. 196/2003 "Tutela della privacy" e art. 616 Codice penale "Violazione, sottrazione e soppressione di corrispondenza"), and may constitute a more serious offence. Thanks.
ACHTUNG!
Dieses Dokument ist ausschließlich dem Empfänger vorbehalten. Die darin enthaltenen Informationen, auch jene in etwaigen Anlagen, gelten im Sinne des Dekrets Nr. 196/2003 in Sachen "Privacy" als streng vertraulich und dürfen von anderen Personen nicht verwende werden. Wer diese Mitteilung irrtümlicherweise erhält ist gebeten uns umgehend zu informieren und anschließend die Mitteilung zu vernichten. Vielen Dank.
