[mapserver-users] WMS, SLD, FilterEncoding and PropertyIsLike
Guillaume Sueur guillaume.sueur at neogeo-online.net
Mon Jun 30 05:45:38 EDT 2008
seen, thanks.
shame on me for having followed the wrong specification paper !
But actually, isn't MapServer behaviour a bit weird when it applies the
misconfigured filter on every record ?
Guillaume
bartvde at osgis.nl a écrit :
> <4864E58F.1020007 at neogeo-online.net>
> <4864E781.7010809 at dmsolutions.ca> <4868A508.6020008 at neogeo-online.net>
> Message-ID: <3fa2d6410a8df0a7b10f97bce0857f39 at pop02.backbone.tiscomhosting.nl>
> X-Sender: bartvde at osgis.nl
> Received: from b50-11.minvenw.nl [145.50.39.11] with HTTP/1.1 (POST); Mon, 30
> 	Jun 2008 11:30:40 +0200
> User-Agent: RoundCube Webmail/0.1
> Content-Type: text/plain; charset="UTF-8"
> Content-Transfer-Encoding: 8bit
> No Mapserver is right in this case it uses SLD 1.0 which is tied to Filter
> 1.0, see:
> http://schemas.opengis.net/filter/1.0.0/filter.xsd
> <xsd:attribute name="escape" type="xsd:string" use="required"/>
> Btw, in Filter 1.1 the OGC changed this to:
> http://schemas.opengis.net/filter/1.1.0/filter.xsd
> <xsd:attribute name="escapeChar" type="xsd:string" use="required"/>
> Best regards,
> Bart
> On Mon, 30 Jun 2008 11:19:04 +0200, Guillaume Sueur
> <guillaume.sueur at neogeo-online.net> wrote:
>> Folks, I've found the trick !
>> Where OGC SLD specification says :
>> <PropertyIsLike wildCard="*" singleChar="#" escapeChar="!">
>> MapServer wants :
>> <PropertyIsLike wildCard="*" singleChar="#" escape="!">
>> Using the first expression with MapServer causes the filter set with it
>> to apply to every records.
>> Should I submit a ticket for this ?
>> Guillaume
>> Yewondwossen Assefa a écrit :
>>> Guillaume,
>>>  Attaches is an sld I use for testing and mapsever returns the expected
>>> results. If you do not mind sharing your sld, you can send it to me and
>>> I can have a look.
>>> Best Regards,
>>> Guillaume Sueur wrote:
>>>> actually it helped me going further in my analysis :
>>>> when I use PropertyIsLike, it traps all the records, even those non
>>>> matching with the pattern.
>>>> Is that a mapserver bug on WMS-SLD handling  ?
>>>> Thanks
>>>> Oscar Gomez a écrit :
>>>>> Hi Guillaume,
>>>>> In the past it worked for me, but I had to look very carefully at the
>>>>> symbology specification from OGC.
>>>>> Here you are my example:
>>>>> <sld:Rule>
>>>>> * * <sld:Name />
>>>>> *-* <http://www12.asphost4free.com/ogomez2/temp/wise.xml#> <sld:Title>
>>>>> *-* <![CDATA[
>>>>> * * </sld:Title>
>> <ogc:Filter>
>>>>> <ogc:PropertyIsLike wildCard="***" singleChar="*#*" escapeChar="*!*">
>>>>> * * <ogc:PropertyName>*ORIGENAGUA*</ogc:PropertyName>
>>>>> * * <ogc:Literal>*Subter**</ogc:Literal>
>>>>> * * </ogc:PropertyIsLike>
>>>>> * * </ogc:Filter>
>>>>> <sld:PolygonSymbolizer>
>>>>> *-* <http://www12.asphost4free.com/ogomez2/temp/wise.xml#> <sld:Fill>
>>>>> <sld:GraphicFill>
>> <sld:Graphic>
>>>>> *-* <http://www12.asphost4free.com/ogomez2/temp/wise.xml#> <sld:Mark>
>>>>> * * <sld:WellKnownName>*circle*</sld:WellKnownName>
>>>>> * * <sld:CssParameter name="*fill*">*#A87000*</sld:CssParameter>
>>>>> * * <sld:CssParameter name="*fill-opacity*">*1.0*</sld:CssParameter>
>>>>> * * </sld:Fill>
>>>>> * * </sld:Mark>
>>>>> * * <sld:Size>*1*</sld:Size>
>>>>> * * </sld:Graphic>
>>>>> * * </sld:GraphicFill>
>>>>> * * </sld:Fill>
>> <sld:Stroke>
>>>>> * * <sld:CssParameter name="*stroke*">*#A87000*</sld:CssParameter>
>>>>> * * <sld:CssParameter name="*stroke-width*">*1*</sld:CssParameter>
>>>>> * * <sld:CssParameter name="*stroke-opacity*">*1*</sld:CssParameter>
>>>>> * * </sld:Stroke>
>>>>> * * </sld:PolygonSymbolizer>
>>>>> * * </sld:Rule>
>>>>> I hope you find it useful. Best,
>>>>> Oscar
>>>>> On Fri, Jun 27, 2008 at 10:00 AM, Guillaume Sueur
>>>>> <mailto:guillaume.sueur at neogeo-online.net>> wrote:
>>>>>     Hi
>>>>>     Has anyone ever had a PropertyIsLike filter working on a WMS layer
>>>>>     I have an SLD file with several rules, all of them with
>>>>>     PropertyIsEqualTo Filter. It works ok.
>>>>>     If I change one of these to PropertyIsLike (I add wildcard,
>>>>>     singleChar and escapeChar as well), they ALL go wrong, none of the
>>>>>     filters being used. All my objects are then shown with the default
>>>>>     representation placed at the end of the file without any filter.
>>>>>     Any idea about this strange behaviour ?
>>>>>     Thanks
