[MAPSERVER-USERS] Missing required parameter BBOX
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Mar 6 06:32:20 EST 2008
BBOX is a required parameter of the WMS standard, which MapServer implements as of 5.0. See http://mapserver.gis.umn.edu/docs/faq/ogc-wms-getmap-required-parameters for more details.
Given your ServiceException, it looks like you are missing the BBOX parameter in your GetMap request.
..Tom
From: mapserver-users-bounces at lists.osgeo.org on behalf of Rahkonen Jukka
Sent: Thu 06-Mar-08 03:36
To: Christopher Schmidt; mapserver-users at lists.osgeo.org
Subject: Re: [MAPSERVER-USERS] Missing required parameter BBOX
If it used to work before, and if you just changed projection of the mapfile to epsg:4326 withour changing the mapfile EXTENTS, the correcting extents might well make it work again.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Christopher Schmidt
> Lähetetty: 5. maaliskuuta 2008 21:35
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: Re: [MAPSERVER-USERS] Missing required parameter BBOX
> On Wed, Mar 05, 2008 at 11:31:34AM -0800, cfb wrote:
> > Hi again,
> > I'm having problems with the projections of my WMS (working with
> > MapServer
> > 5.0.2 for Windows). I've changed the SRS of the header's
> mapfile into
> > EPSG
> > 4326 (before it was EPSG 23030), and also the epsg of one
> layer (which
> > reference system I'd already changed to 4326). I'd left the other
> > layer with EPSG 23030.
> > When I try to GetMap with a client the WMS works but I
> don't see the
> > image (sid), I get this error:
> > "msWMSLoadGetMapParams(): WMS server error. Missing
> required parameter BBOX"
> What is the URL you are using? Does it have a bbox in it?
> Christopher Schmidt
> MetaCarta
