[MAPSERVER-USERS] Tile4ms pre-cached images loses quality
Sacha Black sacha.black at gmail.com
Tue Mar 11 23:59:19 EDT 2008
Ambastha,
are you also trying to use AGG here ? with tile.php? if so you might
be affected by this discussion / solution from the Ka-Map list:
http://www.nabble.com/Ka-map-and-AGG-%2B-Alpha----Solved-%28need-confirm%29-to15973299.html
Sacha
On Tue, Mar 11, 2008 at 8:51 PM, riteshambastha <ritesh.linux at gmail.com> wrote:
>  Dear Mapserver Geniuses,
>  I have used pre-caching script for my ka-map based map. The pre-cached
>  images doesn't retain the same quality compared to on-the-fly generation of
>  images. I am using png24 outputformat. Is it true that the tiled pre-cached
>  images normally lose their quality? Is there any solution for solving this
>  issue?
>  Your suggestions will be highly appreciated.
>  Regards,
>  Ambastha
>  View this message in context: http://www.nabble.com/Tile4ms-pre-cached-images-loses-quality-tp15997333p15997333.html
>  Sent from the Mapserver - User mailing list archive at Nabble.com.
>  _______________________________________________
>  mapserver-users mailing list
>  mapserver-users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapserver-users
