[mapserver-users] Farsi right-to-left labels
Yewondwossen Assefa yassefa at dmsolutions.ca
Wed Mar 12 16:01:30 EDT 2008
Stephen Woodbridge wrote:
> Hi Daniel,
> I looked at the patch briefly.
> It doesn't seem to be doing character joining for works in Arabic.
> I'm thinking that if we had the algorithm to do the joining then we
> could add that and maybe a Tag or metadata item that enabled the joining
>  if needed. The joining algorithm, might be smart enough to only join
> Arabic letters and leave the rest alone.
> If you are interested, I think I can get my hands on a perl script that
> does the joining.
Steve,
  Isn't is what the function shape_arabic (from the PostArabic) module
does?  If that is the case, the source code in C and an original perl
source code are available on the web.
Best Regards,
> -Steve W
> Daniel Morissette wrote:
>> Copying what I wrote earlier this morning on the ka-map list (sorry
>> for those on both lists):
>> FYI there is an open MapServer ticket about this:
>>   http://trac.osgeo.org/mapserver/ticket/956
>> The ticket even includes a patch that you may want to try. I'll try to
>> address this one for MapServer 5.2.
>> Daniel
>> R Isfahani wrote:
>>> Hi,
>>> I'm trying to render some Farsi (Persian) labels on my map. As you
>>> may know, Farsi words are written from right to left, just like Hebrew.
>>> I've changed the label's encoding to 'Windows-1256' in my mapfile and
>>> I'm using TrueType fonts. Farsi letters have appeared. But the
>>> problem is that letters are in revers order and letters are not
>>> joining properly.
>>> Of course reversing the letters' order in database will cause the
>>> right order of them when rendering the map. But I wanna know if
>>> there's any other way to show farsi labels in right order with no
>>> joining problems.
>>> [Actually, I'm using Ka-Map on the top of Mapserver to render my maps
>>> on the web. Ka-Mappers told me that my problem is a kind of Mapserver
>>> problems]
>>> Any new ideas are welcomed.
>>> Thanx.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
