[mapserver-users] GRID labeling, OK, where are the MapServer GRID guru's??
Brent Fraser bfraser at geoanalytic.com
Tue Mar 18 21:46:07 EDT 2008
Bob,
  Good on you for pursuing this!  While I think the current grid object
satisfies most of mapserver implementors' needs, there is room for
improvement.  The ultimate would be a system that can produce reference
system labels like those found on topos (some are very similar to your
NG labels).
First, I see there is still a typo in mapgraticule.c, line 347 (current
SVN) should be
dStartY              = (pInfo->pboundinglines[0].point[1].y -
pInfo->pboundinglines[0].point[0].y) * dDeltaX +
pInfo->pboundinglines[0].point[0].y;
(note the last array index value of 0 not 1)
Second, (from my old notes on experimenting with labeling in v4.3) I
changed 661 thru 682 to:
  switch( ePosition )
    case posBottom:
      pShape->line->point[1].y = pLayer->map->height;
      pShape->line->point[0].y = pLayer->map->height - (
fabs(rectLabel.maxx - rectLabel.minx) + 15 );  /* rectLabel is based
on non-rotated text (x is along the width of text) */
      break;
    case posTop:
      pShape->line->point[1].y = 0;
      pShape->line->point[0].y = fabs(rectLabel.maxx - rectLabel.minx) + 15;
      break;
    case posLeft:
      pShape->line->point[1].x = 0;
      pShape->line->point[0].x = fabs(rectLabel.maxx - rectLabel.minx) + 15;
      break;
    case posRight:
      pShape->line->point[1].x = pLayer->map->width;
      pShape->line->point[0].x = pLayer->map->width - (
      break;
And regarding labeling "outside" the map, I arranged my map file to draw:
1. all the usual raster and vector layers
2. a grid layer
3. a "margin" layer of blanking polygons (see below)
4. a grid layer of type annotation so no lines are drawn
Here's part of my map file (for version 4.3 so no telling what will happen
with v5.x):
SIZE 800 600
LAYER
  NAME "Margin"
  TRANSFORM FALSE
  STATUS DEFAULT
  TYPE POLYGON
  CLASS
     COLOR 255 255 255
  END
  FEATURE
     POINTS 0 0 0 600 70 600 70 0 0 0 END
     POINTS 70 0 70 70 800 70 800 0 70 0 END
     POINTS 70 600 800 600 800 530 70 530 70 600 END
     POINTS 730 70 730 530 800 530 800 70 730 70 END
  END
END
LAYER
  NAME "NeatLine"
  TRANSFORM FALSE
  STATUS DEFAULT
  TYPE LINE
  CLASS
     COLOR 0 0 0
  END
  FEATURE
     POINTS 70 70 70 530 730 530 730 70 70 70 END
  END
END
LAYER
  NAME "GRID"
  PROJECTION
	  "proj=latlong"
#	  "ellps=sphere"
	  "datum=WGS84"
  END
#  TYPE Line
  TYPE ANNOTATION
#  LABELCACHE off
  STATUS DEFAULT
  CLASS
	COLOR 128 128 128
#	  LABEL
#		TYPE BITMAP
#		SIZE MEDIUM
#		COLOR 128 128 89
#	  END
        LABEL
          color 0 0 0
#          COLOR 255 255 0
#          OUTLINECOLOR 0 0 0
          TYPE TRUETYPE
          FONT arial  #bd
          SIZE 12
          POSITION UC # AUTO
          ANGLE AUTO
#          OFFSET 4 4
#          PARTIALS false
#          WRAP " "
        END # Label
  END
  GRID
    LABELFORMAT "DDMM"
#    LABELFORMAT "DDMMSS"
#    MINSUBDIVIDE 6
#    MAXSUBDIVIDE 6
#    MININTERVAL 1.0
#    MAXINTERVAL 1.0
#    MINARCS 6
#    MAXARCS 6
  END
END
END  # MAPFILE
  But in the end it is somewhat hacky and not perfect.  I think some
additional objects and properties are needed.  Last year I had a small
rant regarding graticules on the OSGeo mailing list (with no specific
solution reached).  Here's one record of it:
http://www.mail-archive.com/discuss@lists.osgeo.org/msg00935.html
Keep up the good work!
Brent Fraser
> All,
> I've (we've) been messing with this GRID object and Labeling while trying
> to get a USNG grid output with labels
> The results are meant to look like the left edge of the attached image.
> The other three sides are being repositioned by some semi-known process.
> Essentially the labels should be:
> First two characters are super-scripted, the next two characters are
> Normal, and the last four are also super-scripted.   We've mussed with
> MapServer code and come up with a method for handling the different
> styling via a layer in the MAPFILE, using  a LABELFORMAT option of NG1(1st
> 2 chars), NG2 (2nd 2 chars) and NG3 (the last 4 chars).  This is set up
> along the lines of the DDMMSS options for LAT/LON.
> You can see that there is something wonky about the justification of the
> labels.  Right now we have space padding in front of and behind the
> superscripted items, we'll address that separately once we get past this
> label justification thing.
> So the question is, what is the sequence of events for a GRID with labels,
> being applied to the result?  Where in the Code could/should the
> justifications be eliminated for the GRID writing process (I understand
> that there needs to be a process for aligning along the edges) so that the
> regular Labeling parameters, specifically, the OFFSET param, are adhered
> to.
> I've tried all sorts of different combinations of settings to get the
> right output, and I can only seem to get one edge to display properly.
> Furthering this output option a little more, anyone done any work with
> labeling along the outside of a map image?  I could use an option like
> this for printing for example.
> Thanks
> bobb
> The image results are from using this MapFile:
> MAP
>   NAME 'USNG'
>   SIZE 800 650
>   STATUS ON
>   ##IMAGECOLOR 254 254 254
>   ##EXTENT 540000 135000 600000 175000
>   EXTENT 593133.398829 170094.734526 593893.148973 170712.010326
>   UNITS FEET
>   FONTSET ./0000_00/MN_Line_Experiments/fonts/font.list
>   SYMBOLSET ./0000_00/MN_Line_Experiments/symbols/symbol.list
>   TRANSPARENT TRUE
>   IMAGETYPE PNG
>   WEB
>     IMAGEPATH "/mnt/VECTOR00/output/"
>     IMAGEURL "/tmp/"
>   END
> # EPSG:26915
>   LAYER
>     NAME "grid"
>     TYPE LINE
>     STATUS DEFAULT
>     CLASS
>       NAME "Graticule"
>       COLOR 0 0 0
>       SYMBOL 'circle'
>       SIZE 1
>     END
>     PROJECTION
>       "init=epsg:26915"
>     END
>     GRID
>       LABELFORMAT "NG1"
>     END
>   END
>   LAYER
>     NAME "ng1"
>     TYPE LINE
>     STATUS DEFAULT
>     CLASS
>       LABEL
>         COLOR  0 0 0
>         FONT mono
>         TYPE truetype
>         SIZE 6
>         OUTLINECOLOR 255 255 254
>         FORCE true
>         POSITION cl
>         #OFFSET 0 0
>       END
>     END
>     PROJECTION
>       "init=epsg:26915"
>     END
>     GRID
>       LABELFORMAT "NG1"
>     END
>   END
>   LAYER
>     NAME "ng2"
>     TYPE LINE
>     STATUS DEFAULT
>     CLASS
>       LABEL
>         COLOR  0 0 0
>         FONT mono
>         TYPE truetype
>         SIZE 12
>         FORCE true
>         POSITION cl
>       END
>     END
>     PROJECTION
>       "init=epsg:26915"
>     END
>     GRID
>       LABELFORMAT "NG2"
>     END
>   END
>   LAYER
>     NAME "ng3"
>     TYPE LINE
>     STATUS DEFAULT
>     CLASS
>       LABEL
>         COLOR  0 0 0
>         FONT mono
>         TYPE truetype
>         SIZE 6
>         FORCE true
>         #OFFSET 0 0
>         POSITION cl
>       END
>     END
>     PROJECTION
>       "init=epsg:26915"
>     END
>     GRID
>       LABELFORMAT "NG3"
>     END
>   END
> END ## end Map
> mapserver-users at lists.osgeo.org
