Fwd: [MAPSERVER-USERS] Fwd: CLOSE_CONNECTION=DEFER - Segmentation fault
Dave Fuhry dfuhry at gmail.com
Fri Mar 21 13:12:50 EDT 2008
Ivan,
   Yes, I updated the patch on the bug report page
http://trac.osgeo.org/mapserver/ticket/2497 around the time I sent
those emails yesterday.  Download it, make sure it differs from the
ms_postgis_fix_trans_state.diff you're currently using, `svn revert
mappostgis.c`, and try it with the new patch.
   Sorry that was not clear.
Thanks,
Dave
On Fri, Mar 21, 2008 at 4:59 AM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> On Thursday 20 March 2008 23:46, you wrote:
>  > Ivan,
>  >    Try the new version of the patch, just posted.  I had accidentally
>  > removed a necessary query in msPOSTGISLayerGetShape.  My tests which
>  > now include getShape() are working (with or without PROCESSING
>  > "CLOSE_CONNECTION=DEFER").
>  Hi Dave,
>  I have allready tried patch ms_postgis_fix_trans_state.diff and I have posted
>  the report. Or is there any updated version of
>  ms_postgis_fix_trans_state.diff?
>  I am sure that I have updated php_mapscript.so.
>  For sure I include my report of testing ms_postgis_fix_trans_state.diff:
>  I have applied new patch ms_postgis_fix_trans_state.diff to mapserver-5.0.2
>  sources from debian unstable and recompiled new debian package and install.
>  Then I have:
>  1. restarted apache
>  2. restarted postgresql-8.1
>  3. restarted browser (deleted cache)
>  And started this test with p.mapper 3.2 application:
>  1. Browsing the map (moving, zooming out, zooming in, adding some more layers)
>  2. Using identify ({map,layer}Obj_queryBy{Point,Rect,etc.}) - ERROR:
>  cursor "mycursor2 immediately
>  3. Browsing the map (moving, zooming out, zooming in)
>  4. Using identify ({map,layer}Obj_queryBy{Point,Rect,etc.}) - ERROR:
>  Result:
>  With this patch it is not possible to do neither a singel object query. (with
>  older patch it was possible few times).
>  After "ERROR:  cursor "mycursor2" does not exist" it is possible to continue
>  browsing the map again and object query fill finish with same result as
>  above.
> {map,layer}Obj_queryBy{Point,Rect,etc.} function is not
>  working   also when  #PROCESSING "CLOSE_CONNECTION=DEFER" is disabled.
>  So identify object is not working at all.
>  log is here:
>  http://projects.gpsmapy.sk/logs/ms_postgis_fix_trans_state_patch.log
