SV: [MAPSERVER-USERS] image in an output
James Lindstorff
jlf at eniro.dk
Mon Mar 24 08:41:24 EDT 2008
If you look at
http://mapserver.gis.umn.edu/docs/faq/copyright-layer
You should be able to use the SYMBOL keywork of the CLASS definition to insert your compass.
One problem though, if your images are not of a known size you can't relablily place labels or symbols except in the upper left corner of the image.
/james
-----Oprindelig meddelelse-----
Fra: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] På vegne af Kristian Thy
Sendt: 23. marts 2008 23:21
Til: mapserver-users at lists.osgeo.org
Emne: Re: [MAPSERVER-USERS] image in an output
On Sat, Mar 22, nickthegreek- wrote:
> fist in my output i try to insert in mapfile a image so as to display
> a compass.. what i do is to try to put in mapfile a layer which shows
> only this image, the compass... i haven't tried that up now..any help
> would be great (what exactly to write in the layer)!!!
http://mapserver.gis.umn.edu/docs/reference/mapfile/feature
However, you can't use a picture for that as far as I know ... but if you could make/find a font with a compass glyph, you should be able to insert that.
> and secondly ..i wanna a big help in how to insert my shapefiles in a
> database.. the postgis does that? what i should know is if i should
> put shp shx and dbf files in tables in postgis??
To load shapefiles into PostGIS you use the shp2pgsql utility distributed with PostGIS:
http://postgis.refractions.net/docs/ch04.html#id2670802
\\kristian
... et nemo ex vobis interrogat me: »Quo vadis?« _______________________________________________
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
