[MAPSERVER-USERS] PHP MapScript AGG
Daniel Morissette
dmorissette at mapgears.com
Mon Mar 24 11:36:42 EDT 2008
> Bryn Roberts-2 wrote:
>> Everything works fine but the following two lines seem not to trigger AGG
>> rendering (I have never tried setting output format options from within
>> MapScript before and was unable to find any examples).
>> $map->outputformat->setOption("name", "AGG");
>> $map->outputformat->setOption("imagemode", MS_IMAGEMODE_RGB);
>> $map->outputformat->setOption("driver", "AGG/PNG");
>> Can somebody set me straight and point out where I am going wrong?
The setOption() method is for FORMATOPTIONs only. Name, imagemode and
driver are properties of the OutputFormatObj class and are set using the
set() method:
$map->outputformat->set("name", "AGG");
$map->outputformat->set("imagemode", MS_IMAGEMODE_RGB);
$map->outputformat->set("driver", "AGG/PNG");
BTW, I believe a predefined "AGGPNG24" output format is available by
default, so you could simply select it using:
$map->selectOutputFormat("AGGPNG24");
Daniel
Daniel Morissette
http://www.mapgears.com/
