Rép. : [mapserver-users] Problem creating WMS
Daniel Morissette dmorissette at mapgears.com
Thu Mar 27 14:15:31 EDT 2008
There seems to be lots of confusion around wms_name these days... just
to clarify: when setting up a WMS service, it is the layer's NAME member
that is used as the name in the GetCapabilities output. The wms_name
metadata has no effect on WMS servers, it is a WMS client (i.e.
CONNECTIONTYPE WMS) parameter only.
Daniel
SIMON MERCIER wrote:
> Hi bernardo
> for your layer, you need a "wms_name"... to use a getFeatureInfo you
> need to add (DUMP TRUE) and (TEMPLATE "../templates/todo.html")... the
> html file dont need to exist...!  it's a good idea to specify a
> TOLERENCE to restrict the search in the map... and use
> "gml_include_items" and "ows_exclude_items" in metadata..  if you work
> with a RDBMS(postgis or Oracle) dont forget to add your primary key
> field off your feature class( ... USING UNIQUE ID ...  ) in your DATA
> tag layer... good luck
>    LAYER
>         NAME "LEP_V_MUNICIPALITE_GEO"
>         GROUP "DGEQ"
>         CONNECTIONTYPE oraclespatial
>         CONNECTION "{..}"
>         PROCESSING "CLOSE_CONNECTION=DEFER"
>         DATA "geom_s FROM ADMGEO1.LEP_V_MUNICIPALITE_GEO USING UNIQUE ID
> SRID 32198"
>         TYPE POLYGON
>         DUMP TRUE
>         TOLERANCE 10
>         TOLERANCEUNITS PIXELS
>         MAXSCALE 700000
>         MINSCALE 1
>         LABELMAXSCALE 200000
>         LABELMINSCALE 1
>         LABELITEM "NM_MUNCP"
>         METADATA
>             "wms_group_title"       "Référentiel d'adresse"
>             "wms_name"              "LEP_V_MUNICIPALITE_GEO"
>             "wms_title"             "Municipalité"
>             "wms_keywordlist"       ""
>             "wms_server_version"    "1.1.1"
>             "wms_abstract"          "(1/700 000)"
>             "wms_srs"               "EPSG:2036 EPSG:2037 EPSG:2148
> EPSG:2149 EPSG:2150 EPSG:4269 EPSG:4326 EPSG:26917 EPSG:26918 EPSG:26919
> EPSG:26920 EPSG:32183 EPSG:32184 EPSG:32185 EPSG:32186 EPSG:32187
> EPSG:32188 EPSG:32189 EPSG:32190 EPSG:32198 EPSG:42105 EPSG:42304"
>             "wms_extent"            "-1100000 -23500 1100000 2253500"
>             "gml_include_items"     "all"
>             "gml_exclude_items"     "ID"
>             "ows_include_items"     "all"
>             "ows_exclude_items"     "ID"
>         END
>         PROJECTION
>             "init=epsg:32198"
>         END
>         CLASS
>             NAME "Municipalité"
>             LABEL
>                 OUTLINECOLOR 235 235 235    #--Halo
>                 TYPE TRUETYPE
>                 FONT "vera"
>                 SIZE 8
>                 POSITION AUTO
>                 COLOR 123 104 238
>                 MINDISTANCE 50000
>                 BUFFER 10
>             END
>             STYLE
>                 SYMBOL 'line_solid'
>                 OUTLINECOLOR 123 104 238
>                 SIZE 1
>             END
>         END
>     END
> Simon mercier
> Ministère de la Sécurité publique
>  >>> "bernardo" <bernardo at incargis.com> 25/3/2008 18:35 >>>
> Hello all:
> I'm trying to create a WMS, but i need to use it with a client named
> "gvSIG". This program cannot read feature info in type "text/html", only
> "gml"
>            METADATA
>               "wms_title"               "Layer"
>               "wms_srs"                 "EPSG:23030"
>               "wms_abstract"         "Layer"
>               "wms_feature_info_mime_type"  "gml"
>               #"wms_feature_info_mime_type"  "text/html"
>           END
> That i wanna do is to show a web page or url for "feature info".
> Any ideas?
> Bernardo Martín García
> Director Técnico
> iNCARGiS, C.I.G., S.L.
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
