[mapserver-users] finding php_mapserver.so
Tim McGeary tmm8 at Lehigh.EDU
Thu May 1 11:09:00 EDT 2008
I did specify the --with-php=DIR as --with-php=/usr/include/php/
Here's the output of the configure script for the PHP/Mapscript:
configure: checking for PHP/MapScript module options...
checking for g++ -shared ... yes
checking for location of config.h or php_config.h...
/usr/include/php//main/php_config.h
checking whether we have PHP3 or PHP4... -DPHP4
checking whether we should use PHP's regex... yes
    found regex_extra.h - building PHP MapScript with PHP's bundled regex
    PHP/MapScript module configured.
checking if --enable-runpath requested... no
checking if --with-java-include-os-name specified... no, autodetected linux
configure: creating ./config.status
config.status: creating Makefile
config.status: creating mapscript/php3/Makefile
config.status: creating mapscript/java/Makefile
config.status: creating mapscript/csharp/Makefile
MapServer is now configured for
  -------------- Compiler Info -------------
   C compiler:                gcc -O2 -fPIC -Wall
   C++ compiler:              g++ -O2 -fPIC -Wall
   Debug:                      -DNEED_NONBLOCKING_STDERR
   Generic NINT:
   Threading support:
  -------------- Renderer Settings ---------
   zlib support:
   png support:
   jpeg support:              -DUSE_JPEG
   iconv support:             -DUSE_ICONV
   AGG support:
   AGG Freetype support:
   Ming(flash) support:
   PDFLib support:
  -------------- Data Format Drivers -------
   native tiff support:       -DUSE_TIFF
   PostGIS support:
   Proj.4 support:
   EPPL7 support:             -DUSE_EPPL
   ArcSDE support:
   OGR support:
   GDAL support:
   GEOS support:
   Oracle Spatial support:
   FastCGI support:
  -------------- OGC Services --------------
   WMS Server:
   WMS Client:
   WFS Server:
   WFS Client:
   WCS Server:
   SOS Server:
  -------------- MapScript -----------------
   PHP MapScript:             yes
FYI, I'm running PHP 5.1.6
Tim
Tim McGeary
Senior Systems Specialist
Lehigh University
610-758-4998
tim.mcgeary at lehigh.edu
Google Talk: timmcgeary
Yahoo IM: timmcgeary
Kyle Wilcox wrote:
> Did you specify the --with-php=DIR?
> DIR is obviously the directory of the php version you want to use.
> Step through the output from ./configure and see what it says about
> PHP/Mapscript.  I think it is towards the end.
> Tim McGeary wrote:
>> No, it isn't there.  I did a:
>>    find / -name php_mapscript.so
>> and it came up with nothing.  So it isn't on the server at all.  Yes,
>> I did install Mapserver from source.
>> Here's what is in mapscript/php3
>> [root at rust php3]# pwd
>> /usr/local/mapserver-5.0.2/mapscript/php3
>> [root at rust php3]# ls -l
>> total 716
>> drwxr-xr-x  2 root root   4096 Jan 28 10:56 examples
>> -rw-r--r--  1 root root   2103 Jul 26  2004 hashtable_i.c
>> -rw-r--r--  1 root root   4344 Apr 29 15:37 Makefile
>> -rwxr-xr-x  1 root root   3770 Jun 11  2007 Makefile.in
>> -rwxr-xr-x  1 root root   2097 Feb 14  2006 Makefile.vc
>> -rwxr-xr-x  1 root root  34328 Aug 16  2007 mapscript_i.c
>> -rw-r--r--  1 root root   1049 Feb 14  2006 nmake.opt
>> -rwxr-xr-x  1 root root 502728 Jan  8 12:04 php_mapscript.c
>> -rwxr-xr-x  1 root root  16760 Aug 16  2007 php_mapscript.h
>> -rw-r--r--  1 root root  17046 Jun 15  2007 php_mapscript_util.c
>> -rw-r--r--  1 root root   7450 Jun 15  2007 php_mapscript_util.h
>> -rw-r--r--  1 root root  25958 Jun 14  2005 php_proj.c
>> -rw-r--r--  1 root root   3103 Jul 23  2007 php_regex.c
>> -rwxr-xr-x  1 root root  68315 Jan  8 12:04 README
>> -rwxr-xr-x  1 root root   3821 Jun 21  2001 README.WIN32
>> Thanks,
>> Tim
>> Tim McGeary
>> Lehigh University
>> 610-758-4998
>> Kyle Wilcox wrote:
>>> If you installed Mapserver from source with the  ---with-php=DIR
>>> option and everything went ok, the php_mapscript.so file will be
>>> located in the mapscript/php3/ directory.  Copy this file to your PHP
>>> extensions directory.   You can find the extensions directory by
>>> doing a ]$ php -i | grep extension_dir.
>>> You may want to rename php_mapscript.so to something like
>>> php_mapscript_MAPSERVERVERSION.so.
>>> There a setting in the pmapper config files called msVersion.  You
>>> must set this to MAPSERVERSION if you change the name of the file.
>>> Tim McGeary wrote:
>>>> So our installation of Mapserver, in combination, with PMapper, we
>>>> are getting an error that it cannot find php_mapserver.so.  While I
>>>> configured Mapserver to work with PHP, and it went through fine, I
>>>> cannot find the php_mapserver.so file anywhere on my server.
>>>> Was it supposed to be delivered in the mapserver package?  If so,
>>>> where would it have gone?  If not, where can I find it?
>>>> Thanks,
>>>> Tim
