[MAPSERVER-USERS] Any other Routing solution than pgRouting/Oracle NDM ?
riteshambastha ritesh.linux at gmail.com
Fri May 2 10:56:44 EDT 2008
Thanks Steve,
Route computation is taking an average time of 1.2 sec.
Post this, showing route on the browser takes a lot of time.
I am not using kamap xml overlay and any lib of openlayers.
I am posting this route result xml into a db, and allowing a map file to
read this db and show the route on map.
I know this is not an efficient way to do the job.
I got to know that openlayers libs can help me to achieve the same. I want
to know how in-efficient will be to use kamap xml overlay instead of any fn
of openlayers.
Regards,
Ritesh Ambastha
Stephen Woodbridge wrote:
> riteshambastha wrote:
>> Dear friends,
>> I have seen routing based on postgis routing and oracle network data
>> models.
>> Even though, they serve the purpose very efficiently, they take some
>> 1sec/2sec/3sec to display the routes. I checked them with OpenLayers and
>> Ka-map. Still, I feel there must be a way to reduce this route display
>> time.
>> Is there any any other ways to show routing/directions over mapserver
>> based
>> maps? Any other data structure and programming in C/python can serve the
>> purpose ?
> What is taking too long?
> 1) is it the route computation
> 2) transfering the route data to OpenLayers
> 3) rendering the route data as a vector layer
> Have you considered writing some code on the server that generates an
> image file from the route data and returns a url for the image that can
> be then pinned to OpenLayers like a marker? You could do this by writing
> a wrapper in your favorite scripting language around the request to
> generate the route.
> -Steve W
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Any-other-Routing-solution-than-pgRouting-Oracle-NDM---tp17001397p17021074.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
