[MAPSERVER-USERS] problem with GeomFromText - updating PostGis table
SUSANNE susanne.kalliany at tefis.at
Mon May 5 02:39:59 EDT 2008
Hello to everyone,
I have a mapserver/PostGreSQL/PostGis application where I am now able to
show PostGis layers.
To insert lines I want to set following commands with php:
$sql_i = "insert into zobject3 (the_geom) VALUES (GeomFromText('linestring
(-99232 261118,-98232 262118)',31282) ) ";
pg_query($sql_i);
I get following error message:
Query failed: ERROR Invalid OGC WKT (does not start with P,L,M,C or G)
Inserting a (non geomtric parameter) with following command works OK:
$sql_i = "insert into zobject3 (name) VALUES ("test")
pg_query($sql_i);
I would be very pleased if anyone can give me some usefull hint.
Thanks a lot,
Susanne Kalliany
View this message in context: http://www.nabble.com/problem-with-GeomFromText---updating-PostGis-table-tp17053945p17053945.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
