[MAPSERVER-USERS] problem with GeomFromText - updating PostGis table
Brent Wood pcreso at pcreso.com
Mon May 5 03:07:16 EDT 2008
--- SUSANNE <susanne.kalliany at tefis.at> wrote:
Hi Susanne,
Try having LINESTRING (upper case) instead of linestring.
HTH,
  Brent Wood
> Hello to everyone,
> I have a mapserver/PostGreSQL/PostGis application where I am now able to
> show PostGis layers.
> To insert lines I want to set following commands with php:
> $sql_i = "insert into zobject3 (the_geom) VALUES (GeomFromText('linestring
> (-99232 261118,-98232 262118)',31282) ) ";
> pg_query($sql_i);
> I get following error message:
> Query failed: ERROR Invalid OGC WKT (does not start with P,L,M,C or G)
> Inserting a (non geomtric parameter) with following command works OK:
> $sql_i = "insert into zobject3 (name) VALUES ("test")
> pg_query($sql_i);
> I would be very pleased if anyone can give me some usefull hint.
> Thanks a lot,
> Susanne Kalliany
http://www.nabble.com/problem-with-GeomFromText---updating-PostGis-table-tp17053946p17053946.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
