[mapserver-dev] Re: AW: [mapserver-users] Rendering of Static
Text is different usinggd or AGG ?
thomas bonfort
thomas.bonfort at gmail.com
Tue May 6 11:36:52 EDT 2008
This should already be fixed in trunk.
regards,
thomas
On Tue, May 6, 2008 at 6:29 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Created a bug for this:
> http://trac.osgeo.org/mapserver/ticket/2607
> Schönhammer, Herbert wrote:
> > Hi Steve,
> > Hi Jeff,
> > the workaround of jeff is working.
> > I think, this is a bug, but I don't know how to generate a bug !
> > Could anybody do this for me ? (Only if there are more people who think,
> this is a bug !)
> > Thanks very much,
> > Herbert
> > > -----Ursprüngliche Nachricht-----
> > > Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Stephen
> Woodbridge
> > > Gesendet: Dienstag, 6. Mai 2008 17:20
> > > An: Jeff McKenna
> > > Cc: mapserver-dev; Mapserver-users
> > > Betreff: Re: [mapserver-users] Rendering of Static Text is different
> usinggd or AGG ?
> > > Jeff,
> > > This is a good work around, but I think we need to ask the questions:
> > > What is the expected behavior?
> > > Is this a bug, should it be a bug?
> > > Should this behavior be documented?
> > > Should this be bugged for 5.2 freeze?
> > > Clearly some code is translating the © for the GD renderer.
> > > Adding cc: mapserver-dev, let me know If you want to to generate a bug
> based on this and assign it to 5.2
> > > -Steve W
> > > Jeff McKenna wrote:
> > > > What about using your operating system's character set? For
> > > example on
> > > > windows pressing ALT-0169 gives the copyright sign, and on
> > > MAC pressing
> > > > OPTION-G. So your mapfile snippet is: TEXT "(c)"
> > > > -jeff
> > > > On 6-May-08, at 9:32 AM, Schönhammer, Herbert wrote:
> > > > > Hi list,
> > > > > Using* gd* the declaration "©"renders the "copyright"-Sign:
> > > > > LAYER
> > > > > NAME "copyright"
> > > > > REQUIRES ..
> > > > > FEATURE
> > > > > POINTS
> > > > > 3 10
> > > > > END
> > > > > END
> > > > > CLASS
> > > > > * TEXT "© xxx" *
> > > > > LABEL
> > > > > TYPE TRUETYPE
> > > > > FONT 'arial'
> > > > > SIZE 9
> > > > > POSITION cr
> > > > > COLOR 0 0 0
> > > > > OUTLINECOLOR 255 255 254
> > > > > END
> > > > > END
> > > > > END # LAYER
> > > > > But using agg, the text ""© xxx" is rendered in the map.
> > > > > Please lokk at the examples !
> > > > > Does anybody know,
> > > > > how to render the html-code like done in gd ?
> > > > > Does anybody know another way to render signs like
> > > "copyright" with gd ?
> > > > > Thanks very much
> > > > > greetings
> > > > > Herbert
> > > > > <<gd-rendering.gif>> <<agg-rendering.gif>>
> > > <gd-rendering.gif><agg-rendering.gif>__________________________
> > > > > mapserver-users mailing list
> > > > > mapserver-users at lists.osgeo.org
> > > <mailto:mapserver-users at lists.osgeo.org>
> > > > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > > > _______________________________________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
