[mapserver-users] Some Problems with WMS-GetLegendGraphic using agg and pixmaps
"Schönhammer, Herbert" Schoenhammer.Herbert at Regensburg.de
Wed May 7 03:26:52 EDT 2008
Hi list,
I have got some troubles generating legends with MS 5.0.2, used as a WMS-Server, using agg - driver and generating the legends from a pixmap with getlegendgraphic-request.
(See the mapfile snippets below !)
First Problem:
Using gd the pixmap referenced by KEYIMAGE is scaled to the size defined by KEYSIZE.
Using agg the pixmap is NOT scaled. A part of the pixmap is shown as legend-graphic. This part is not scaled, size is 100% as in the original pixmap.
(My pixmap is larger than the size defined by KEYSIZE)
Second Problem:
Scaling the original pixmap DOES NOT really solve the problem, because:
Always only a part of the original pixmap is used for generating the legend-graphic: it is the part "cr" (center right) of the pixmap. So, if the original pixmap is scaled, only the "cr"-part is very small drawn in the legend-graphic.
The size of the part is correct after scaling the original pixmap, but always only a part of the original pixmap is shown.
Solution ?
I think this is a bug.
But if you know a workaround, please let us know !
Thanks very much
Herbert
Mapfile Snippets:
 OUTPUTFORMAT
   #NAME png
   #DRIVER "GD/PNG"
   MIMETYPE "image/png"
   NAME 'AGG_Q'
   DRIVER AGG/PNG
   EXTENSION PNG
   IMAGEMODE RGBA
   TRANSPARENT ON
 END
LEGEND
  STATUS ON
  #KEYSIZE 55 40
  KEYSIZE 200 520
  KEYSPACING 10 5
  LABEL
      COLOR 0 0 0
      TYPE TRUETYPE
      FONT "verdana"
      SIZE 8
  END # END LABEL
  TRANSPARENT ON
  IMAGECOLOR 255 255 255
END   #LEGEND
LAYER ...
   CLASS
     NAME "Stadtplan farbig"
     KEYIMAGE "/data/raster/stadtplan/stadtplan_legende_hoch.png"
   END
END # LAYER
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080507/f58a2121/attachment.html
