[mapserver-users] Coverting lat/long to pixel
Hulbert, Brian brian.hulbert at linquest.com
Wed May 7 09:03:15 EDT 2008
Something else to consider if your map uses multiple (or switches between)
"projections".
My C# map application uses both equirectangular and orthographic
projections.  Therefore, I do the following before the lines of code that
Sandeep presented:
            // create a Mapserver pointObj for the point being converted
            pointObj pObj = new pointObj(location.LongitudeDeg,
location.LatitudeDeg, 0, 0);
            // create 2 projection objects - a From projection object (a
latlong projection) and a To projection object (the current projection)
            projectionObj projectionFrom = new projectionObj("+proj=latlong
+ellps=WGS84 +datum=WGS84 +over");
            projectionObj projectionTo = new
projectionObj(m_baseMap.getProjection());
            // perform the projection of the point from the current
projection to a latlong projection; the point's x (lon) and y (lat) are
updated in place
            bool bSuccess = (((int)MS_RETURN_VALUE.MS_SUCCESS) ==
pObj.project(projectionFrom, projectionTo));
            if (bSuccess)
                  // Sandeep's code here
            // cleanup temporary objects
            pObj.Dispose();
            projectionFrom.Dispose();
            projectionTo.Dispose();
Brian
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sucharita
Samuel
Sent: Wednesday, May 07, 2008 7:42 AM
To: Sandeep Kumar Jakkaraju
Cc: mapserver-users
Subject: Re: [mapserver-users] Coverting lat/long to pixel
  Thanks a lot Sandeep. I think the code works.
Regards,
Sucharita
On Wed, May 7, 2008 at 3:40 PM, Sandeep Kumar Jakkaraju
<sandeepkumar.jakkaraju at gmail.com> wrote:
Hi Sucharita
these are example values........
 private double minlat=28.6023 ;
    private double minlon=77.2018 ;
    private double maxlat=28.6382 ;
    private double maxlon=77.2493 ;
    private int screenwidth=2156;
    private int screenheight=1674;
    private Point p;
    public Point convertLatLonToPixel(double lat,double lon)
        double cellsizex = (maxlon-minlon)/screenwidth;
        double cellsizey = (maxlat-minlat)/screenheight;
        int ix = (int) ((lon-minlon)/cellsizex);
        int iy1 = (int) ((maxlat-lat)/cellsizex);
        int iy2 = (int) ((maxlat-lat)/cellsizey);
        int iy = (int) (iy1+iy2)/2;
        p = new Point(ix,iy);
return p;
On 5/7/08, Sucharita Samuel <iworktech.sucharita at gmail.com> wrote:
 Hi Sandeep,
                   A code fragment will be really helpful.
Thanks,
Sucharita
On Wed, May 7, 2008 at 3:20 PM, Sandeep Kumar Jakkaraju
This can be done using simple interpolation also
Hi friends,
              Can somebody please help me with a code to convert the
latitude and longitude of a point to pixel co-ordinates? I am using ASP.NET
<http://asp.net/> . I have heard that GDAL has a method for this conversion.
MS4W comes with GDAL as its tools, but I don't know how to implement it in
C#.NET.
Thanks in advance,
Regards,
Sucharita
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Thanks
Regards
Thanks
Regards
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080507/ab13444b/attachment-0001.html
