[mapserver-users] Layer always turn on (not possible to activate/deactivate)
Emilio Ponce yosoycore at gmail.com
Thu May 8 06:22:40 EDT 2008
Hi Luca, Thanks for your help.
To set no GROUP is not working.. Maybe this is the solution using mapserver
only, but with ka-map if I don't set group to this layer then the other
layers disappear from the legend and in general everything stops work well.
Is there other way?
thanks anyway
2008/5/7 Luca Casagrande <luca.casagrande at gmail.com>:
> Il giorno 07/mag/08, alle ore 19:34, Emilio Ponce ha scritto:
> Hi everyone, here's a newbie question:
> I'm using mapserver with ka-map and I have different layers in a unique
> mapfile. I want to set ONE of this layers always visible, without
> possibility to turn off (deactivate) it. For this purpose I thought the
> STATUS tag on this LAYER was the solution: Status DEFAULT to turn on this
> layer permanently... but it didn't work.
> You have to set no GROUP at all for that layer.
> With this setting, layer will go in "base" group and will stays always on.
> Bye
> Luca Casagrande
> Gubbio (PG)
> "Siamo tutti in una fogna, ma che alcuni di noi guardano le stelle" O.
> Wilde
Emilio
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080508/889996e6/attachment-0001.html
