[mapserver-users] How do I make a shapefile polygon thicker withinUMN Mapserver
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Thu May 8 13:17:26 EDT 2008
John,
One very common approach is to use a symbol for your line style, and
then adjust the size. Viz:
   CLASS
      NAME "proj_seggroups"
      SYMBOL 'circle'
      SIZE 3
      COLOR -1 -1 -1
      BACKGROUNDCOLOR 0 0 0
      OUTLINECOLOR 0 0 0
   END
And then of course, you need to have the symbol 'circle' defined.  This
is done in the top portion of the mapfile (perhaps the order is not
important, but in all the examples I have seen it is there):
SYMBOL
  NAME 'circle'
  TYPE ELLIPSE
  POINTS 1 1 END
  FILLED TRUE
END
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of John
Mitchell
Sent: Thursday, May 08, 2008 1:09 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] How do I make a shapefile polygon thicker
withinUMN Mapserver
How do I make a shapefile polygon thicker within UMN Mapserver?
I have listed below the layer that correctly displays the outlines
contained within the shapefile, but I can't figure out how to make the
polygon outlines thicker.
LAYER
  # name of layer
  NAME stlouisxdrive
  GROUP "gv:stlouisxdrive"
  PROJECTION
   "init=epsg:26915"
  END
  # what type of data is this?
  TYPE POLYGON
  DATA "C:/TEMP/64Resolution"
  # always returned with interface
  STATUS ON
        CLASS
        OUTLINECOLOR 255 0 0
        END
 END
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080508/8cce1ebb/attachment.html
