[mapserver-users] How do I make a shapefile polygon thicker
within UMN Mapserver
Dean Gadoury
deangadoury at gmail.com
Thu May 8 13:23:30 EDT 2008
I don't think you can change the thickness of a polygon's outline. You may
have to draw the layer twice, once as TYPE POLYGON, then again ad TYPE LINE.
MapServer actually allows you to draw polygon features as lines. With line
layers you can change the thickness of features.
Your second layer could be done like this:
LAYER
NAME stlouisxdrive
GROUP "gv:stlouisxdrive"
PROJECTION
"init=epsg:26915"
END
TYPE LINE
DATA "C:/TEMP/64Resolution"
STATUS ON
CLASS
STYLE
COLOR 255 0 0
END
END
On Thu, May 8, 2008 at 1:09 PM, John Mitchell <mitchelljj98 at gmail.com>
wrote:
> Hi,
> How do I make a shapefile polygon thicker within UMN Mapserver?
> I have listed below the layer that correctly displays the outlines
> contained within the shapefile, but I can't figure out how to make the
> polygon outlines thicker.
> LAYER
> # name of layer
> NAME stlouisxdrive
> PROJECTION
> "init=epsg:26915"
> END
> # what type of data is this?
> TYPE POLYGON
> # always returned with interface
> STATUS ON
> CLASS
> OUTLINECOLOR 255 0 0
> END
> END
> John J. Mitchell
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080508/d4493805/attachment.html
