[mapserver-users] ROSA applet with PHP Mapscript
Carlo Pelliconi
c.pelliconi at sis-ter.it
Fri May 9 07:47:26 EDT 2008
Thank you very much, I will use those links.
Regards, Carlo
Daniel Morissette ha scritto:
> Carlo Pelliconi wrote:
>> Hi all.
>> I'm trying to use ROSA applet with PHPMapscript (I had jbox with cgi
>> mapserver, and I'd like to have similar functions).
>> Looking for documentation (both in web and in downloaded .tar), I've
>> found only few pages.
>> Does anyone know any link with deeper documentation or usage examples?
>> But it is not necessary to use ROSA: is there something other, which
>> can be used for the same tasks?
> FYI the mapserv CGI also has support for ROSA applet parameters, see
> at the bottom of this page:
> http://mapserver.gis.umn.edu/docs/reference/cgi/controls
> Unfortunately that documentation doesn't include usage examples so
> you'd have to figure the way to setup your mapserv CGI template yourself.
> With respect to ROSA with PHP MapScript, there is the good old GMap
> demo app that uses both. Not the best example of good coding, but at
> least that's something to get started. You can download the GMap demo
> with all scripts and data at http://dl.maptools.org/dl/gmap-ms46.zip
> and you can see it online at http://www.mapsherpa.com/gmap/
> Daniel
ing. Carlo Pelliconi
SIS.TER S.p.A.
www.sis-ter.it
via Mentana, 10
40026 Imola (BO) Italy
tel +39 0542 364034
fax +39 0542 612130
ATTENZIONE!
Questo documento è indirizzato esclusivamente al destinatario. Tutte le
informazioni ivi contenute, compresi eventuali allegati, sono soggette
a riservatezza secondo i termini del D.Lgs. 196/2003 in materia di
"privacy" e ne è proibita l'utilizzazione da parte di altri soggetti. Si ricorda che la diffusione l'utilizzo e/o la conservazione dei dati ricevuti per errore costituisce violazione di carattere penale ai sensi dell'art. 616 Codice penale (Violazione, sottrazione e soppressione di corrispondenza). Se avesse ricevuto per errore questo messaggio, La preghiamo cortesemente di contattare il mittente al più presto e di cancellare il messaggio subito dopo. Grazie.
ATTENTION!
This message is being sent from Sis.Ter S.p.A. and may contain information which is confidential or privileged. If you are not the intended recipient, please advise the sender immediately by reply e-mail and delete this message and any attachments without retaining a copy. Any unauthorized use of the content of this message is a breach of your duty to respect the confidentiality of the correspondence between other persons and can expose the responsible party to civil and/or criminal penalties (D.Lgs. 196/2003 "Tutela della privacy" e art. 616 Codice penale "Violazione, sottrazione e soppressione di corrispondenza"), and may constitute a more serious offence. Thanks.
ACHTUNG!
Dieses Dokument ist ausschließlich dem Empfänger vorbehalten. Die darin enthaltenen Informationen, auch jene in etwaigen Anlagen, gelten im Sinne des Dekrets Nr. 196/2003 in Sachen "Privacy" als streng vertraulich und dürfen von anderen Personen nicht verwende werden. Wer diese Mitteilung irrtümlicherweise erhält ist gebeten uns umgehend zu informieren und anschließend die Mitteilung zu vernichten. Vielen Dank.
