[mapserver-users] PostGIS problems in nightly
Håvard Tveite
havard.tveite at umb.no
Fri May 9 12:15:33 EDT 2008
I want to report a small problem I faced with a PostGIS
connection with the latest nightly build.
With the latest build I have problems with one of my
PostGIS connections.
The problem goes away when I switch back to the nightly
build from March 4th 2008. Other PostGIS connections
seem to work fine on both builds.
The mapserver_log reports:
Fri May 9 17:08:42 2008,2747,128.39.236.206,okart,0,-19379.849812 26500.000000 19379.849812 57500.000000,-1.000000 -1.000000,o-kartpoint o-kartpolygon o-kartline ,msDrawMap(): Image handling error. Failed to draw layer named 'o-kartpoint'. <br>
prepare_database(): Query error. Error declaring cursor: ERROR: current transaction is aborted, commands ignored until end of transaction block
With query string: DECLARE mycursor BINARY CURSOR FOR SELECT "symbol"::text,"direction"::text,asbinary(force_collection(force_2d(the_geom)),'XDR'),OID::text from (select oid, symbol, trim(both ' ' from direction) as direction, the_geom from okartpoint order by sequence) as okart WHERE the_geom && setSRID('BOX3D(-19379.8498122653 26500,19379.8498122653 57500)'::BOX3D, -1 )
<br>
msPOSTGISLayerRetrievePK(): Query error. Error executing POSTGIS statement (msPOSTGISLayerRetrievePK():select attname from pg_attribute, pg_constraint, pg_class where pg_constraint.conrelid = pg_class.oid and pg_class.oid = pg_attribute.attrelid and pg_constraint.contype = 'p' and pg_constraint.conkey[1] = pg_attribute.attnum and pg_class.relname = '(select oid, symbol, trim(both ' ' from direction) as direction, the_geom from okartpoint order by sequence) as okart' and pg_table_is_visible(pg_class.oid) and pg_constraint.conkey[2] is null <br>
PostgreSQL log:
2008-05-09 17:08:42 MET DST okart guest 128.39.175.213ERROR: syntax error at or near "' from direction) as direction, the_geom from okartpoint order by sequence) as okart'" at character 283
MapServer version 5.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=SDE INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
PostgreSQL 8.1.5, POSTGIS="1.3.2" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS
I am on Solaris 2.7
If I remove the trim statement ("trim(both ' ' from direction)
as direction"), and replace it with "direction" (untrimmed) there
is no error situation in the latest nightly.
Is this a bug?
Regards,
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
