[MAPSERVER-USERS] Transparencies and IE6
Ritesh Ambastha
group.ritesh at gmail.com
Sat May 10 07:24:35 EDT 2008
Yes, this is a known issue for IE6.
I hope FF and IE7 works fine with your program.
It should work with Firefox. Else, you must check your code.
Regards,
Ritesh
Bart van den Eijnden wrote:
> This a known issue/bug in IE6.
> You can use a png hack to overcome this problem (though performance might
> be an issue), e.g.:
> http://code.google.com/p/pnghack/
> Best regards,
> Bart
> On Thu, 8 May 2008 10:51:39 -0400, "Nelson Soto" <nellyfromma at gmail.com>
> wrote:
>> I am having trouble getting cross-browser uniformity with MapServer.
>> None of my transparent-enabled layers appear to draw at all under IE6
>> and in Firefox 2 The layers draw, but without transparency enabled.
>> They work as expected with IE7 however. Is there a known issue with
>> this?
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://www.nabble.com/Transparencies-and-IE6-tp17129341p17162307.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
