[MAPSERVER-USERS] Layer always turn on (not possible to
activate/deactivate)
Ritesh Ambastha
group.ritesh at gmail.com
Sat May 10 08:03:36 EDT 2008
I would suggest to check the kamap config.php file.
>From mapserver side, it should work
<snip>
STATUS [on|off|default]
Sets the current status of the layer. Often modified by MapServer
itself. Default turns the layer on permanently.
Some notes regarding the STATUS values:
* In CGI mode, layers with STATUS DEFAULT cannot be turned off using
normal mechanisms. It is recommended to set layers to STATUS DEFAULT while
debugging a problem, but set them back to ON/OFF in normal use.
* For WMS, layers in the server mapfile with STATUS DEFAULT are
always sent to the client.
</snip>
Regards,
Ambastha
Luca Casagrande wrote:
> Il giorno 07/mag/08, alle ore 19:34, Emilio Ponce ha scritto:
>> Hi everyone, here's a newbie question:
>> I'm using mapserver with ka-map and I have different layers in a
>> unique mapfile. I want to set ONE of this layers always visible,
>> without possibility to turn off (deactivate) it. For this purpose I
>> thought the STATUS tag on this LAYER was the solution: Status
>> DEFAULT to turn on this layer permanently... but it didn't work.
> You have to set no GROUP at all for that layer.
> With this setting, layer will go in "base" group and will stays
> always on.
> Bye
> Luca Casagrande
> Gubbio (PG)
> "Siamo tutti in una fogna, ma che alcuni di noi guardano le stelle"
> O. Wilde
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Layer-always-turn-on-%28not-possible-to-activate-deactivate%29-tp17110472p17162596.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
