[mapserver-users] PostGIS problems in nightly
Stephen Woodbridge
woodbri at swoodbridge.com
Sun May 11 10:48:28 EDT 2008
Havard,
This sounds like a bug, can you create a bug on this so it gets resolved
for 5.2. If not let me know, and I'll write on.
Thanks,
-Steve W
Havard Tveite wrote:
> Sorry for not testing more, Steve. Answers to your questions
> below.
> Stephen Woodbridge wrote:
>> Håvard,
>> Try:
>> trim(both from direction)
> works
>> which does the same thing as:
>> trim(both ' ' from direction)
>> this looks like it might be an unescaped ' and in single quotes string.
>> you could also try:
>> trim(both \' \' from direction)
> does not work (still "crash").
>> or
>> trim(both \\' \\' from direction)
> Regards,
> Håvard
>> and report if either of these work.
>> This would help narrow down the issue and maybe give you a work around.
>> -Steve W
>> Håvard Tveite wrote:
>>> I want to report a small problem I faced with a PostGIS
>>> connection with the latest nightly build.
>>> With the latest build I have problems with one of my
>>> PostGIS connections.
>>> The problem goes away when I switch back to the nightly
>>> build from March 4th 2008. Other PostGIS connections
>>> seem to work fine on both builds.
>>> The mapserver_log reports:
>>> Fri May 9 17:08:42 2008,2747,128.39.236.206,okart,0,-19379.849812
>>> 26500.000000 19379.849812 57500.000000,-1.000000 -1.000000,o-kartpoint
>>> o-kartpolygon o-kartline ,msDrawMap(): Image handling error. Failed to
>>> draw layer named 'o-kartpoint'. <br>
>>> prepare_database(): Query error. Error declaring cursor: ERROR: current
>>> transaction is aborted, commands ignored until end of transaction block
>>> With query string: DECLARE mycursor BINARY CURSOR FOR SELECT
>>> "symbol"::text,"direction"::text,asbinary(force_collection(force_2d(the_geom)),'XDR'),OID::text
>>> from (select oid, symbol, trim(both ' ' from direction) as direction,
>>> the_geom from okartpoint order by sequence) as okart WHERE the_geom &&
>>> setSRID('BOX3D(-19379.8498122653 26500,19379.8498122653 57500)'::BOX3D,
>>> -1 )
>>> <br>
>>> msPOSTGISLayerRetrievePK(): Query error. Error executing POSTGIS
>>> statement (msPOSTGISLayerRetrievePK():select attname from pg_attribute,
>>> pg_constraint, pg_class where pg_constraint.conrelid = pg_class.oid and
>>> pg_class.oid = pg_attribute.attrelid and pg_constraint.contype = 'p' and
>>> pg_constraint.conkey[1] = pg_attribute.attnum and pg_class.relname =
>>> '(select oid, symbol, trim(both ' ' from direction) as direction,
>>> the_geom from okartpoint order by sequence) as okart' and
>>> pg_table_is_visible(pg_class.oid) and pg_constraint.conkey[2] is null
>>> <br>
>>> PostgreSQL log:
>>> 2008-05-09 17:08:42 MET DST okart guest 128.39.175.213ERROR: syntax
>>> error at or near "' from direction) as direction, the_geom from
>>> okartpoint order by sequence) as okart'" at character 283
>>> MapServer version 5.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>> OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>>> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=EPPL7
>>> INPUT=SDE INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>> PostgreSQL 8.1.5, POSTGIS="1.3.2" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel.
>>> 4.5.0, 22 Oct 2006" USE_STATS
>>> I am on Solaris 2.7
>>> If I remove the trim statement ("trim(both ' ' from direction)
>>> as direction"), and replace it with "direction" (untrimmed) there
>>> is no error situation in the latest nightly.
>>> Is this a bug?
>>> Regards,
