[mapserver-users] How to draw a circle with a centroid and radius
Sucharita Samuel
iworktech.sucharita at gmail.com
Mon May 12 06:31:15 EDT 2008
Hi Friends,
I am really stuck up with this for a long time now. As far as
I have googled, I have found that to draw a circle, either using a mapfile
or dynamically using a mapscript, the circle has to be defined by two set of
points of its bounding rectangle. The image that I get on my screen is a
circle (because the layer is defined as a circle), but to draw this circle,
a set of two points is used which ultimately is a line. I will provide my
code sample below,
DrawCircle(double x, double y, double dRadius)
double minx = x - dRadius;
double miny = y + dRadius;
double maxx = x + dRadius;
double maxy = y - dRadius;
//upper left corner of the bounding rectangle
pointObj oPointMin = pixel2point(new pointObj(minx, miny, 0, 0));
//lower right corner of the bounding rectangle
pointObj oPointMax = pixel2point(new pointObj(maxx, maxy, 0, 0));
lineObj oLine = new lineObj();
oLine.add(oPointMin);
oLine.add(oPointMax);
shapeObj oShp = new shapeObj((int)MS_SHAPE_TYPE.MS_SHAPE_LINE);
oShp.add(oLine);
// Creation of a temporary layer (for circle)
layerObj oTempLayer = new layerObj(map);
oTempLayer.name = "UserCircle";
oTempLayer.status = 1;
oTempLayer.type = MS_LAYER_TYPE.MS_LAYER_CIRCLE;
classObj oTempClass = new classObj(oTempLayer);
styleObj oStyle = new styleObj(oTempClass);
oStyle.outlinecolor.setRGB(0, 0, 0);
oStyle.color.setRGB(255, 227, 255);
oTempLayer.addFeature(oShp);
In the last line, I add the shape object to the temporary layer and
then draw that layer which thus gives me a circle. But now, I want to find
the intersection of this circle with the underlying layer features which I
am unable to do, as the circle is not actually a circle or polygon that will
give me the intersection and thus the area of intersection.
The link
http://lists.dmsolutions.ca/pipermail/mapserver-users/2004-March/016983.html
has a code sample to draw a circle with polygon but that code doesn't seem
to work because it does not give me a circle but some other shaped polygon.
Friends, please help me with this problem.
Thanks,
Sucharita.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080512/77fe09a4/attachment.html
