[mapserver-users] AGG vs. GD: Label placement problems
thomas bonfort
thomas.bonfort at gmail.com
Mon May 12 13:38:57 EDT 2008
This issue should now be fixed in trunk, if you have time to confirm
that would be great!
regards,
thomas
On Tue, Mar 18, 2008 at 2:10 PM, thomas bonfort
<thomas.bonfort at gmail.com> wrote:
> http://trac.osgeo.org/mapserver/ticket/2357
> On Tue, Mar 18, 2008 at 1:05 PM, Doyon, Jean-Francois
> <jdoyon at nrcan.gc.ca> wrote:
> > Thanks Thomas, that'd be great ... is there a ticket open for this, or
> > should I open one? (I'd like to track progress on this issue ...)
> > J.F.
> > -----Original Message-----
> > From: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of thomas
> > bonfort
> > Sent: March 18, 2008 03:42
> > Cc: mapserver-users at lists.osgeo.org
> > Subject: Re: [mapserver-users] AGG vs. GD: Label placement problems
> > Yes, that's exactly the problem, as there's a difference of a few pixels
> > between the size of the label calculated by gd and the size it actually
> > takes when rendered with agg. I realize now that it can cause some quite
> > visible problems in the case you show here (labels to the left), as in
> > that case the few pixels difference can cause the label to overlap the
> > point symbol. I'll see if I can fix this in the days/weeks to come so
> > this can be included in 5.2
> > cheers,
> > thomas
> > On Mon, Mar 17, 2008 at 8:25 PM, Daniel Morissette
> > <dmorissette at mapgears.com> wrote:
> > > Doyon, Jean-Francois wrote:
> > > > Labels that are to the left of the point seem to be placed
> > differently ... Look top-right ("Les Escoumins", "Saint Anne de Port
> > Neuf", etc ...) for an example, though it happens all over the place I
> > think. Labels to the right of the point however seem ok.
> > > > Is this a bug? A design change? Can anything be done from the
> > mapfiel to mitigate this?
> > > A few days ago, ThomasB wrote on mapserver-dev that in AGG mode, "gd
> > > is still used [...] for the calculation of label sizes (thus some
> > > subtle discreptancies in label placement, mostly visible if using a
> > > label
> > > backgroundcolor)":
> > > http://lists.osgeo.org/pipermail/mapserver-dev/2008-March/006868.html
> > > Maybe that's what your running into? Hopefully Thomas will see this
> > > and comment.
> > > Daniel
> > > Daniel Morissette
> > > http://www.mapgears.com/
> > > _______________________________________________
> > > mapserver-users mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
