[mapserver-users] Temporary image files
Walter Lorenzetti lorenzetti at faunalia.it
Tue May 13 04:12:01 EDT 2008
Frank Broniewski ha scritto:
Hi Frank,
> Hi List
> I am just setting up a web server for use with mapserver. Targeted use will be
> php-mapscript and wms map serving.
> I was just looking through my mapfiles in order to find file system based
> configurations like shapepath, imagepath etc.
> Stumbling over imagepath and imageurl parameters, I was wondering for what
> reason mapserver stores the images in the temporary folder before serving
> them to the user. When querying mapserver as a wms, there are no temporary
> files, so this does not seem to be a necessary step to provide a map image to
> the user.
> Does mapserver reuse these images? Or is the temporary files approach a remain
> from more static web map pages where the image could be reused more often?
I know this is not possible, because mapserver uses timestamp...
but I don't sure...
> Coming to my next question, I presume that my php code causes the storage of
> the image - $mapimageurl = $mapimage->saveWebImage();
> Is it possible to deliver the image directly to the browser instead of passing
> an URI?
yes is possible, you've to use $img->saveImage(''); instead of
and in your php page you've to use
header('Content-type: image/png');
if you use png format image, image/jpeg for jpeg etc...
I hope this can help
W
Please no  .doc, .xls, .ppt, .dwg:
https://www.faunalia.it/dokuwiki/doku.php?id=public:OpenFormats
Walter Lorenzetti
email+jabber: lorenzetti at faunalia.it
www.faunalia.it
Cell: (+39) 347-6597931  Tel+Fax: (+39) 0587-213742
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy
