[mapserver-users] Build Mapserver 5.0.2 with sde support on solaris
5.8
Oliver Wesp
oliver.wesp at gmail.com
Thu May 15 02:29:45 EDT 2008
Dear List,
I'm trying to build mapserver 5.0.2 with support for sde 9.2 on my
solaris 5.8 box. The following problem occurs:
Undefined first referenced
symbol in file
__1cG__CrunKpure_error6F_v_
/export/home/oliver/sde_client/sdeexe92/lib/libsde.so
__1cG__CrunIex_alloc6FI_pv_
__1cG__CrunIex_throw6Fpvpkn0AQstatic_type_info_pF1_v_v_
__1cG__CrunKvector_des6FpvIIpF1_v_v_
__1cG__CrunKvector_con6FpvIIpF1_vp2_v_
__fabsf
__floorf
__1cG__CrunKvector_del6FpvIpF1_v_1_
__1cG__CrunGex_get6F_pv_
__1cG__CrunMex_rethrow_q6F_v_
__1cG__CrunKvector_new6FpvIIpF1_vp2_1_
__1cG__CrunSregister_exit_code6FpG_v_v_
__1cG__CrunHex_skip6F_b_
__1cG__CrunIex_clean6F_v_
__1cG__CrunKex_rethrow6F_v_
c::c(N6, (int0_t))
c::c(n6, (int0_t))
__1c2K6Fpv_v_
__1c2k6Fpv_v_
ld: fatal: Symbol referencing errors. No output written to shp2img
collect2: ld returned 1 exit status
I guess the missing references are in libCrun.so.1 so I tried to add
"-L/usr/lib -lCrun" but that gives me "libCrun not found" but
libCrun.so.1 is located in /usr/lib.
Any ideas?
I'm trying to build with gcc 3.2.3.
best regards,
Oliver
