[MAPSERVER-USERS] instantclient-basic-win32-11.1.0.6.0 and MS4W 2.2.7
Lucena, Ivan ivan.lucena at pmldnet.com
Thu May 15 19:58:07 EDT 2008
What is Oracle version you have? Is it 11.1.0.6.0? I guess that function
was deprecated. Take a look at: http://www.gdal.org/ogr/drv_oci.html and
http://download.osgeo.org/gdal/win32/1.5/ that is what you find on the
OCI zip README.TXT:
OGR 1.5 Oracle Plugin
Install
Unzip on top of the gdalwin32exe15x package.  It will put the
plugin in gdalwin32-1.5\bin\gdalplugins.
If you don't already have Oracle 10.2 OCI libraries available, you
will need to download the Oracle 10.2 Instant Client (you will need an
OTN login):
http://download-uk.oracle.com/otn/nt/instantclient/instantclient-basiclite-win32-10.2.0.3-20061115.zip
The Oracle DLLs can be placed in gdalwin32-1.5\bin or anywhere else in the
path.
If all this is successful "ogrinfo --formats" should list the OCI driver.
Good Luck.
Myopic wrote:
> Has anyone had problems or tried to get Oracle Spatial to work with MS4W
> 2.2.7 with
> instantclient-basic-win32-11.1.0.6.0?
> When I replace the dlls as per the readme..
> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html
>  I get the the following error when I do the "ogrinfo --formats" command:
> "The procedure entry point OCICollTRIM could not be located in the dynamic
> link library oci.dll"
> Which oracle client should I be using?
> Many thanks!
> (I apologize for the double post..)
