[mapserver-users] Trouble compiling 5.0.2 with AGG on Centos 4
Jacolin Yves
yjacolin at free.fr
Fri May 16 07:00:19 EDT 2008
Hi Dominik,
You can try to run ldconfig to update your lib system database, and/or to
add --with-ogr parameter to ./configure (but it seems already done)
Y.
Le Friday 16 May 2008 12:31:29 Dominik Schmid, vous avez écrit :
> Hi Guillaume
> thanks for the advice, somehow I hadn't tried that combination. I'm
> still not sure if AGG is going to work at all but at least Mapserver
> compiled.
> In the next attempt I added some more options (--with-proj, --with-geos
> etc., as per instructions on
> http://www.darandandunguen.org/2008/02/01/como-instalacion-de-mapserver-5-c
>on-postgis-en-rhel5howto-mapserver-5-and-postgis-in-rhel5/ about 3/4 down
> the page) and now configure chokes on OGR. I get the following error:
> configure: checking whether we should include WMS Server support...
> OGC WMS compatibility enabled (-DUSE_WMS_SVR).
> configure: checking whether we should include WFS Server support...
> configure: error: OGC WFS Server support cannot be enabled: missing OGR
> which is required).
> Checking the gdal config:
> # /usr/bin/gdal-config --ogr-enabled
> yes
> Looking for the GDAL files:
> # ls /usr/lib | grep -i gdal
> libgdal.a
> libgdal.la
> libgdal.so
> libgdal.so.1
> libgdal.so.1.11.0
> # ls /usr/bin/ | grep -i gdal
> gdal2xyz.py
> gdaladdo
> gdalchksum.py
> gdal-config
> gdal_contour
> gdalimport.py
> gdalinfo
> gdal_merge.py
> gdal_rasterize
> gdaltindex
> gdal_translate
> gdalwarp
> # ls /usr/include/gdal | grep -i gdal
> gdal_alg.h
> gdal_frmts.h
> gdal.h
> gdaljp2metadata.h
> gdal_pam.h
> gdal_priv.h
> gdal_rat.h
> gdal_version.h
> gdalwarper.h
> So GDAL seems to be installed properly. Where else could the problem be
> located?
> Thanks for any insight
> Dominik
> Guillaume Sueur schrieb:
> > try
> > --with-freetype=/usr/bin
> > and
> > --with-agg=/path/to/agg/build/dir
> > Guillaume
> > Dominik Schmid a écrit :
> >> We've finally decided to move forward and replace our ageing Mapserver
> >> 4.0.1 installation with the latest and greatest version.
> >> I came as far as thinking that the AGG make was successfull, but when
> >> I try to configure Mapserver ("/.configure -with-agg
> >> --with-freetype") I get the following error:
> >> configure: error: freetype required for agg support - please configure
> >> --with-freetype
> >> I did include some directories with both options with the same result.
> >> I'm not sure where AGG is exactly installed (directly in "agg-2.x" or
> >> in a subdirectory in there) nor which freetype directory to use
> >> located (the libfreetype.* files are in "/usr/lib" but freetype-config
> >> is in "/usr/bin").
> >> When I check in yum I see that freetype 2.1.9 is in fact installed.
> >> One problem I see is with AGG, I can't get it through Centos 4
> >> repositories so I guess need to compile it myself. I've tried various
> >> instructions:
> >> - http://trac.osgeo.org/mapserver/ticket/2215 (not sure if that's
> >> still valid info)
> >> - Rich Fromm's instructions posted on this list on Nov 27, 2007
> >> The instruction in ticket 2215 don't result in the promised
> >> agg_font_freetype.o file, neither in agg-2.4 nor agg-2.5.
> >> Rich's instructions for build AGG (". autogen.sh") exits with the
> >> following error:
> >> ./configure: line 4513: syntax error near unexpected token 'FREETYPE,'
> >> ./configure: line 4513: 'PKG_CHECK_MODULES(FREETYPE,'
> >> I'm kind of lost with this, so I'm turning to this list for help.
> >> Documentation for installing Mapserver 5 with AGG support seems scarce.
> >> Here's some more system info:
> >> - Centos 4.4
> >> - Apache 2.0.52
> >> - PHP 5.1.6
> >> - pgsql 8.1.8
> >> - freetype and freetype-devel 2.1.9
> >> ... I can give more specs if needed.
> >> Any help is greatly appreciated
> >> Dominik
Yves Jacolin
http://softlibre.gloobe.org
