[mapserver-users] Trouble compiling 5.0.2 with AGG on Centos
4
Dominik Schmid
dominik.schmid at ilu.ch
Fri May 16 10:35:17 EDT 2008
Thanks Guillaume and Yves.
I figured out now what caused the configure to trip in this case because
it tripped over a few more options: I hadn't installed a bunch of
*-devel packages on the test server (they were all installed on our live
server and that's why I didn't have issues there the last time I tried).
This is solved now and I started the make. This, again, threw an error
which I strongly suspect could be because our version of GD is not
up-to-date. These are the last few output lines of make:
include -I/usr/include -I/usr/include/libxml2 -c -o mapagg.o
mapagg.cpp
mapagg.cpp: In function `agg::rendering_buffer gdImg2AGGRB_BGRA(gdImage*)':
mapagg.cpp:201: error: `gdImageGetTrueColorPixel' was not declared in
this scope
mapagg.cpp:201: warning: unused variable 'gdImageGetTrueColorPixel'
make: *** [mapagg.o] Error 1
I'll see if I can get GD properly updated to >=2.0.32 and report back
here when that's accomplished.
Thanks for your help
Dominik
Guillaume Sueur schrieb:
> Yes, as Yves said, please check that you're using the
> --with-ogr=/usr/bin/gdal-config in your mapserver configure options,
> check that all needed libraries paths are references in /etc/ld.so.conf
> run ldconfig
> and make the build dance again.
> Good luck !
Dominik Schmid
Dipl. Umweltnaturwissenschafter ETH
ilu AG
Zentralstrasse 2a
CH-8610 Uster
Tel: +41 44 / 944 55 56 (Direktwahl)
Tel: +41 44 / 944 55 55 (allgemein)
Fax: +41 44 / 944 55 66
mailto:dominik.schmid at ilu.ch
http://www.ilu.ch
