[MAPSERVER-USERS] GD 2.0.35 installed but not found
TallDave
notice at davidbianco.net
Fri May 16 13:24:11 EDT 2008
alim,
Unfortunately, I dont have root access to the machine, so someone else has
to do the lib installs. GD 2.0.35 was already on the machine, so we left
it at that. When I list the gd libs it shows fontconfig as already
available.
unix:/home> gdlib-config --libs
-ljpeg -lfontconfig -lfreetype -lpng12 -lz -lm -liconv
Here is an error grep of my mapserver config.log:
unix:mapserver-5.0.2> grep -i erro config.log
conftest.c:2: error: parse error before "me"
conftest.cc:13: error: `exit' undeclared (first use this function)
conftest.cc:13: error: (Each undeclared identifier is reported only once for
xmlCtxtGetLastError /opt/local/lib/libfontconfig.so.1
ld: fatal: Symbol referencing errors. No output written to conftest
| /* Override any gcc2 internal prototype to avoid an error. */
configure:5807: error: Could not find gd.h or libgd.a/libgd.so in
/opt/local. Make sure GD 2.0.16 or higher is compiled before calling
configure. You may also get this error if you didn't specify the appropriate
location for one of GD's dependencies (freetype, libpng, libjpeg or
libiconv).
and more specifically:
configure:5706: checking whether GD needs libiconv...
configure:5708: checking for gdFontCacheSetup in -lgd
configure:5738: gcc -o conftest -g -O2 -fPIC conftest.c -lgd -ljpeg
-lfreetype -lpng -lz -L/lib -lXpm -lX11 -L/opt/local/lib -L -liconv -lm
-lstdc++ >&5
Undefined first referenced
symbol in file
xmlSAX2GetLineNumber /opt/local/lib/libfontconfig.so.1
collect2: ld returned 1 exit status
configure:5744: $? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #ifdef __cplusplus
| extern "C" void std::exit (int) throw (); using std::exit;
| #endif
| #define YYTEXT_POINTER 1
| #define STDC_HEADERS 1
| /* end confdefs.h. */
| #ifdef __cplusplus
| extern "C"
| #endif
| /* We use char because int might match the return type of a gcc2
| builtin and then its argument prototype would still apply. */
| char gdFontCacheSetup ();
| int
| main ()
| return 0;
configure:5769: result: no
libiconv).
I'm guessing I need to recompile libfontconfig?
Cheers,
Dave
alim karim wrote:
> dave,
> i got this error just yesterday.
> the configure worked for me after re-installing gd with fontconfig support
> (this was on a gentoo machine)
> if you notice, the output just before configure bails is - checking for
> gdFontCacheSetup in -lgd... no
> configure.log might be able to give you more ideas as well. i'd try the
> fontconfig support first.
> ak
> On 5/15/08, TallDave <notice at davidbianco.net> wrote:
>> First time mapserver install. Below is my config script and output.
>> Any
>> insight into why libgd is not working out here? I am running this on
>> Solaris 9. As you can see libgd.so definitely exists in the required
>> directory and it has no problem accessing jpeg, freetype, png, iconv.
>> Thanks!
>> Dave
>> unix:mapserver-5.0.2> cat conf_mapserv.sh
>> # MapServer configure command
>> # May 2 2008
>> ./configure --with-debug \
>> --with-freetype \
>> --with-zlib \
>> --with-png \
>> --with-jpeg \
>> --with-libiconv \
>> --with-gd=/usr/local/lib \
>> --with-proj \
>> --with-threads \
>> --with-ogr \
>> --with-gdal \
>> --with-tiff \
>> --with-oraclespatial \
>> --with-wfs \
>> --with-wcs \
>> --with-wfsclient \
>> --with-wmsclient \
>> --with-curl-config \
>> --with-warnings \
>> --enable-debug
>> unix:mapserver-5.0.2> cat install_mapserver.log
>> checking for gcc... gcc
>> checking for C compiler default output file name... a.out
>> checking whether the C compiler works... yes
>> checking whether we are cross compiling... no
>> checking for suffix of executables...
>> checking for suffix of object files... o
>> checking whether we are using the GNU C compiler... yes
>> checking whether gcc accepts -g... yes
>> checking for gcc option to accept ANSI C... none needed
>> checking for g++... g++
>> checking whether we are using the GNU C++ compiler... yes
>> checking whether g++ accepts -g... yes
>> checking for ranlib... ranlib
>> checking for flex... flex
>> checking for yywrap in -lfl... yes
>> checking lex output file root... lex.yy
>> checking whether yytext is a pointer... yes
>> checking for bison... bison -y
>> checking if compiler supports -R... yes
>> checking for exp in -lm... yes
>> checking for __gxx_personality_v0 in -lstdc++... yes
>> checking how to run the C preprocessor... gcc -E
>> checking for egrep... grep -E
>> checking for ANSI C header files... yes
>> checking for strcasecmp... yes
>> checking for strncasecmp... yes
>> checking for strdup... yes
>> checking for strlcat... yes
>> checking for vsnprintf... yes
>> MapServer Version from mapserver.h: '5.0.2'
>> configure: checking where FreeType 2.x is installed...
>> checking for freetype-config... /usr/local/bin/freetype-config
>> using libfreetype from -L/usr/local/lib -R/usr/local/lib
>> -lfreetype
>> -lz
>> checking for FT_Init_FreeType in -lfreetype... yes
>> using libfreetype -lfreetype from system libs.
>> configure: checking where Zlib is installed...
>> checking for zlibVersion in -lz... yes
>> using libz from system libs (-DUSE_ZLIB).
>> configure: checking where PNG is installed...
>> checking for png_init_io in -lpng... yes
>> using libpng from system libs.
>> configure: checking whether we should include JPEG support...
>> checking for jpeg_read_header in -ljpeg... yes
>> using libjpeg from system libs.
>> configure: checking where libXpm is installed...
>> using libXpm from -L/lib -lXpm -lX11
>> configure: checking where libiconv is installed...
>> checking for iconv_open in -lc... yes
>> checking for libiconv_open in -liconv... yes
>> using libiconv from -L -liconv
>> libiconv found. Enabling internationalization (-DUSE_ICONV)
>> configure: checking for GD 2.0.16 or higher...
>> checking for gdFontCacheSetup in -lgd... no
>> configure: checking whether GD needs libiconv...
>> configure: error: Could not find gd.h or libgd.a/libgd.so in
>> /usr/local/lib.
>> Make sure GD 2.0.16 or higher is compiled before calling configure. You
>> may
>> also get this error if you didn't specify the appropriate location for
>> one
>> of GD's dependencies (freetype, libpng, libjpeg or libiconv).
>> unix:mapserver-5.0.2> ls -l /usr/local/lib/libgd.*
>> -rw-r--r-- 1 root other 806416 May 2 14:33
>> /usr/local/lib/libgd.a
>> -rwxr-xr-x 1 root other 1055 May 2 14:33
>> /usr/local/lib/libgd.la*
>> lrwxrwxrwx 1 root other 14 May 2 14:33
>> /usr/local/lib/libgd.so -> libgd.so.2.0.0*
>> /usr/local/lib/libgd.so.2 -> libgd.so.2.0.0*
>> -rwxr-xr-x 1 root other 815700 May 2 14:33
>> /usr/local/lib/libgd.so.2.0.0*
>> unix:mapserver-5.0.2> grep VERSION /usr/local/include/gd.h
>> #define GD_MAJOR_VERSION 2
>> #define GD_MINOR_VERSION 0
>> #define GD_RELEASE_VERSION 35
>> #define GD_EXTRA_VERSION ""
>> #define GD_VERSION_STRING "2.0.35"
>> View this message in context:
>> http://www.nabble.com/GD-2.0.35-installed-but-not-found-tp17262832p17262832.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://www.nabble.com/GD-2.0.35-installed-but-not-found-tp17262832p17280064.html
