[mapserver-users] Setting up a MAP file to use data on a network
share [newbie I guess! :-) ]
Greg Cocks
gcocks at stoller.com
Fri May 16 17:57:31 EDT 2008
Hello List,
I am trying to set up a MAP file to use a network share for the files that for various reasons I can’t get into PostgreSQL, etc… i.e., so that we only have one copy of the data being used internally and on the web, etc
I proceeded as follows
- Using IIS on a Windoze box (yeah, yeah, grin) set up a virtual directory to a network share using a UNC path \\server\directory that I use all the time with ArcGIS, etc – called it wms_data
- Added my credentials in the ‘Connect As’ in IIS
- Used the explore in the IIS MMC and confirmed I could browse the data there
- Confirmed that the directories had the relevant web access permissions
- Charged the relevant line in my MAP file to → SHAPEPATH "/wms_data/"
- Changed the layer’s data pointer to → DATA "subdirectory/sameshapefilename"
* When I now load the page it says it can’t find the layer’s data! Ugh! *
Note that if I use a local (i.e., C:\...\...\) path for the data and in the MAP file it works just fine… Also, want to look at MrSIDs the same way, which again works just fine using a C:\ path…
Note that I know enough about IIS to be dangerous! ☺
Thanks in advance for your help
Regards,
GREG COCKS
GIS Analyst V
S. M. Stoller Corp
105 Technology Drive, Suite 190
Broomfield, CO 80021
www.stoller.com
303-546-4300
303-443-1408 fax
303-546-4422 direct
303-828-7576 cell
