[mapserver-users] mapext=shapes
Steve Lime Steve.Lime at dnr.state.mn.us
Mon May 19 18:49:20 EDT 2008
I'm afraid not. There may be workarounds though. What type of a query map are you using?
This would be a relatively easy hack if you can compile from source although since you're using Windows
that may not be an option.
Steve
>>> On 5/19/2008 at 12:30 PM, in message
<5a9686e80805191030k50c0dcf8i42902334e2f0110a at mail.gmail.com>, "Mike Saunt"
<mikesaunt at gmail.com> wrote:
> Hi All
> Is there anyway specifying a buffer or factor to the mapext=shapes?
> Bascially I'm zooming to the extents of a poygon from an itemnquery but
> would like the map zoomed out slightly more...
> http://mswebdev:81/cgi-bin5.0/mapserv.exe?&map=D:/Maps/SurreyHeath/_MapServerC
> onfig/myareaquery.map&mode=itemnquery&mapsize=200+150&mapext=shapes&qlayer=LandPa
> rcels&qitem=uprn&qstring=100061560388&map.layer[LandParcels]=TEMPLATE+globexml.x
> ml
> Using standard CGI MapServer 5.0
> Much appreciated
> Mike
